Ranku
- 422
- 18
Is an object with escape velocity in gravitational freefall?
Let me re-frame the question then: Can an object attain escape velocity if it only receives an initial impulse, and not continuously accelerated, such as in a rocket ?Ibix said:Maybe. It depends if it's being accelerated by something or not.
So such an object would be in freefall?Ibix said:Of course. You'd need a very big cannon to be able to do it on Earth, but you can jump hard enough to achieve escape velocity from smaller asteroids.
Ranku said:Let me re-frame the question then: Can an object attain escape velocity if it only receives an initial impulse, and not continuously accelerated, such as in a rocket ?
You're asking a question you've asked before in a different thread. The answer is very simple (if the question is worded properly). It seems like you don't like the answer. What answer were you hoping to get?Ranku said:Let me re-frame the question then: Can an object attain escape velocity if it only receives an initial impulse, and not continuously accelerated, such as in a rocket ?
I had in mind the similarity with a universe that is expanding with or without a cosmological constant, and how to look at matter in terms of whether it is in cosmological freefall or not.russ_watters said:You're asking a question you've asked before in a different thread. The answer is very simple (if the question is worded properly). It seems like you don't like the answer. What answer were you hoping to get?
Does said matter have any rocket engine? Is it moving through a medium? Is it charged or magnetic and in an electromagnetic field? Are there any forces you can think of at all, disregarding gravity (and other spacetime curvature effects if you are thinking of those as distinct from gravity)? No? Then it's in free fall.Ranku said:I had in mind the similarity with a universe that is expanding with or without a cosmological constant, and how to look at matter in terms of whether it is in cosmological freefall or not.
If "free fall" is/was defined as 'without any force other than gravity acting" then it's in free fall.Ibix said:Then it's in free fall.
That's what I'm trying to do - understand, which is something to be arrived at by asking questions about that which one doesn't yet know enough about.sophiecentaur said:If "free fall" is/was defined as 'without any force other than gravity acting" then it's in free fall.
The expression "free fall" was introduced before the New Cosmology arrived and there is little point in trying to make it fit in. This is yet another example of people assigning more importance to the meaning of words and classification than in try to understand what's actually going on.
Ok. Fair enough. But the term “free fall” cannot really be applied to relativistic matters or to expansion. It is an ancient term so I think that ‘understanding’ doesn’t involve it.Ranku said:That's what I'm trying to do - understand, which is something to be arrived at by asking questions about that which one doesn't yet know enough about.
I didn’t actually mean to bring up cosmology in this thread, but then @russ_watters accused me of not liking the answers I had already received about free fall on another thread - so then I mentioned I was trying to see how freefall might fit into the cosmological context, but first I wanted to explore all aspects about freefall; perhaps subsequently, I would have directly asked about freefall and cosmology in a separate thread.Ibix said:It's probably more precise to ask if an object is moving inertially (no forces acting on it - remember that gravity is not a force) than ask about free fall. I'd regard the two terms as equivalent, but @sophiecentaur apparently disagrees. Either way, I do kind of agree with the point that asking about escape velocity is a strange way to start asking about cosmology. Escape velocity isn't really relevant to cosmology. You'd be better served by providing a bit more context to your question - then you don't get twelve posts debating the meaning of "free fall" and its relationship to escape velocity when you are actually interested in the movement of galaxies.
Well, I think that it cannot because it is a Classical idea that was applied to the very simplest of situations. Furthermore, I would suggest that free fall refers only to gravitational forces (i.e. no fancy tricks with E fields and suitable charge distribution etc.). But this is a perfect example of the etymological tail wagging the physical dog and it can only deviate one from the path of 'deeper' understanding.Ranku said:I was trying to see how freefall might fit into the cosmological context,
Escape velocity is the minimum speed required for an object to break free from the gravitational pull of a celestial body, such as a planet or moon. It is the speed at which the object's kinetic energy is equal to the gravitational potential energy of the body.
Escape velocity is calculated using the formula v = √(2GM/r), where v is the escape velocity, G is the gravitational constant, M is the mass of the celestial body, and r is the distance from the center of the body to the object's starting point.
Yes, escape velocity can be achieved on Earth. However, due to Earth's strong gravitational pull, the required speed is very high at approximately 11.2 km/s (25,000 mph). This is why rockets need to reach such high speeds in order to break free from Earth's gravity and enter orbit.
Gravitational freefall is the motion of an object falling under the influence of gravity alone, without any other forces acting on it. It is also known as free fall or weightlessness. In this state, the object is accelerating towards the center of the celestial body at a constant rate, known as the acceleration due to gravity.
Gravitational freefall is closely related to escape velocity because an object that reaches escape velocity will enter a state of freefall, where it is no longer bound by the gravitational pull of the celestial body. However, an object in freefall does not necessarily have to reach escape velocity. For example, satellites in orbit around Earth are in a state of freefall, but they do not travel at escape velocity.
