MHB Estefano's question at Yahoo Answers involving a linear approximation
The discussion revolves around a calculus problem involving the volume of a gold coin that has been altered by a counterfeiter. The original coin is a cylinder with a radius of 10 mm and a thickness of 2 mm, and the problem requires calculating the volume of gold stripped after reducing the radius by 0.1 mm. The linear approximation method is introduced, leading to a calculated volume change of approximately 12 mm³, while the exact calculation yields 13 mm³. The response emphasizes the importance of understanding both linear approximations and exact values in calculus. The thread encourages further engagement with calculus problems in a dedicated forum.
MarkFL
MHB
Here is the question:
Need help with calculus word problem?
Please explain how to solve it.
An ancient counterfeiter clipped the edges of a gold coin. The coin was originally a cylinder with a radius of 10 mm and a thickness of 2 mm, and the counterfeiter stripped 0.1 mm from around the edges. Approximate the amount of gold stripped from this coin to the nearest mm3.
Here is a link to the question:
Need help with calculus word problem? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Estefano,
For problems like this, I like to begin with the approximation:
$$\frac{\Delta V}{\Delta r}\approx\frac{dV}{dr}$$
$$\Delta V\approx\frac{dV}{dr}\cdot\Delta r$$
$$V(r+\Delta r)-V(r)\approx\frac{dV}{dr}\cdot\Delta r$$
Now, with:
$$V=\pi r^2h\,\therefore\,\frac{dV}{dr}=2\pi rh$$
and letting $$r=9.9\text{ mm},\,\Delta r=0.1\text{ mm}$$ we find:
$$V(10)-V(9.9)\approx\left(2\pi(9.9)(2) \right)\cdot(0.1)=3.96\pi\text{ mm}^3$$
For comparison, the exact value of the change in volume is:
$$V(r+\Delta r)-V(r)=\pi(10)^2(2)-\pi(9.9)^2(2)=2\pi(1.99)=3.98\pi\text{ mm}^3$$
Because of rounding to the nearest unit, the linear approximate gives us a change of volume of $12\text{ mm}^3$, whereas the exact value would be rounded to $13\text{ mm}^3$.
To Estefano and any other guests viewing this topic, I invite and encourage you to register and post other calculus problems in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
