MHB Estimate Paint Amount for Hemispherical Dome w/ Differentials
To estimate the amount of paint needed for a hemispherical dome with a diameter of 46 m and a thickness of 0.03 cm, the radius is calculated as 23 m. The volume differential formula used is dv = 2π(23 m)²(0.0003 m). The initial calculation yielded 0.3174, which should be rounded to 0.32. However, the mistake was identified as omitting the π in the calculation. Including π corrected the error, leading to the accurate estimate for the paint required.
Micah2
Use differentials to estimate the amount of paint needed to apply a coat of paint 0.03 cm thick to a hemispherical dome with diameter 46 m. (Round your answer to two decimal places.)
First I list what I am given:
Diameter: 46m
DR: 0.0003m (converted from the 0.03cm that was given)
DV: ?
Volume of a Sphere = 4/3 pi r^3
But volume of a half a Sphere = 2/3 pi r^3
And Radius = Diameter/2
So...dv = 2 pi (23m)^2 (0.0003m)
Using a Calculator I am given 0.3174. The question asks to round it to two decimal places, which would be 0.32.
All homework is done online but apparently this answer is still incorrect. I appreciate all and any help to sort this out. :(
you forgot the $\pi$ ...
Doh! Yes, that did the trick. Thank you so much! :)
31K
11K
12K
13K
