Estimate the radius of the largest asteroid you could escape by jumping
In summary, to estimate the radius of the largest asteroid from which you could escape simply by jumping off, you would need to know the mass and mean density of the asteroid. Using the equation v = Square Root ( ( 2GM ) / r ), where v is your jump speed, G is the gravitational constant, M is the mass of the asteroid, and r is the radius, you can calculate the acceleration due to gravity acting on the person. Then, using the conservation of energy formula, you can find the initial jump velocity and plug it into the equation to solve for the radius. It is also important to note that you need to use the average density of an asteroid, not the average mass, to calculate the radius accurately.
leonne
191
estimate the radius of the largest asteroid from which you could escape simply by jumping off.
R^2= 3gh/4piGp
Would I use this formula to solve it? Found it online but dose not seem right. this is a 2 part problem first one asked for the velocity you get when you jump up and got 1.72e6 cm/s
This question is dependent on the mass of the asteroid (giving the gravitational force).
The lower the mass, the smaller the radius you could jump from to escape its gravitational pull.
Without knowing the mass of the asteroid, you cannot give a radius.
EDIT: I would also avoid using cm/s. You should work in SI units - m/s. Note, the velocity during a jump would not be constant (m/s) you would slow on the initial ascent, stop, and then descend so you should have a value for the initial acceleration of the jump in (m/s^2). On earth, your initial jump acceleration must be > 9.81m/s^2 in order to get you off the floor.
The relevant equation you provided uses g (gravitational acceleration). Although I would ignore this equation and go with the one below.
g = ( G x M1 x M2 ) / r^2
Where: G is the gravitational constant, M1 is the mass of the asteroid, M2 is the mass of the person jumping and r is the radius of the asteroid.
Once you know all those factors you can calculate the acceleration due to gravity acting on the person. Once you have that, you know what acceleration you need to escape the asteroids gravity.
ok thxs ill try it out
Hey just wonder could you use the escape velocity to find out? v=(2GM/r)^1/2 v would be the velocity i figured out jumping on Earth then plug in the other and solve for r
Again, you have M there. This is the mass of the asteroid. You need a mass for the asteroid, once you have this, we can plug in G, M and v and rearrange to get r.
Is that everything you were given in the question?
well it says you will need to make an assumption about the mean density that's why I used that first equation cause it had density, but i guess does not matter much
Ah so there was more to it. If you have a radius and know the mean density for an asteroid, you can calculate the mass.
I would use the equation vescape = Square Root ( ( 2GM ) / r )
Where vescape = your jump speed, G = gravitational constant, M = mass of asteroid, r = radius
M = volume x density
vescape = Square Root ( ( 2GVD ) / r )
Where V = volume, D = mean density
Now assume the asteroid is a sphere to simplify things, substitute in the formula for the volume of a sphere instead of V in the above. From there you should be able to see how you can rearrange to get the answer. Let me know how you get on.
k thxs got it
What value did you get for r?
I have to question, do you believe you can jump at 17200m/s on Earth? How did you calculate this value.
o um i used the conservation on energy pei +kei = pef kef found that pe= mgh then something about transferring the same energy into kinetics. didnt take general physics since 3 years so forgot lol then did 0 +kei = 3e8 +3e8 solve for kei then plug that in kinetics to find v also for avg mass i found that all the asteroid in the solar system have a mass about .o2 of the moon so found the mass of all then found there is about 1mill asteroid so divided that to find mass of 1
edit ok i think i see the problem when i found kei i got 9e16 but did something wrong and should be 6e8
You need to use the average density of an asteroid, not the average mass. Your question does say to use mean density of an asteroid.
Once you have the average density, you can plug it into the equation I gave above (and following my outline) you can calculate the radius.
To calculate your initial jump velocity, you either need the height you jumped or the time you were in the air.
If you know t:
Using v = u + at, rearrange to give u = ?
If you know height s:
Using v^2 = u^2 + 2as, rearrange to give u = ?
Where v = final velocity, u = initial velocity, a = acceleration, t = time in air
Remember, acceleration will be opposite to the direction of travel and t = the time taken from start to peak jump height, not the entire jump up, stop down.
Once you've done that, you have your v for my previous equation.
Plug all the values in and rearrange to give you the r value based on your maximum possible escape velocity.
ok thanks
Related to Estimate the radius of the largest asteroid you could escape by jumping
1. What is the largest asteroid known to exist?
The largest asteroid known to exist is Ceres, which has a diameter of approximately 940 kilometers (580 miles).
2. How do scientists estimate the radius of an asteroid?
Scientists use various methods to estimate the radius of an asteroid, such as measuring its size and shape from images taken by spacecraft or using data from ground-based telescopes.
3. Can an asteroid be large enough to escape by jumping?
Yes, an asteroid can be large enough for a person to escape by jumping. The gravity on smaller asteroids is much weaker than on Earth, making it possible to jump off the surface.
4. What factors affect the ability to escape an asteroid by jumping?
The main factor is the size and mass of the asteroid. The smaller and less massive the asteroid, the weaker its gravity and the easier it would be to escape by jumping. Other factors such as the surface terrain and the strength of the person's jump also play a role.
5. Is it possible to estimate the radius of an asteroid accurately?
While scientists can estimate the radius of an asteroid using various methods, it is not always possible to determine the exact size with complete accuracy. Some asteroids have irregular shapes or are covered in dust, making it challenging to get a precise measurement. However, these estimates can still provide valuable information about the asteroid's size and potential hazards.
13K
