Estimating Error in Meas. of Homog. Mag Field w/ Hall Effect Probe
In summary, the Gauss-meter has an error in the orientation of the probe, which will propagate to the measurement of the magnetic field. This error can be estimated using a Taylor expansion.
OGrowli
I'm trying to estimate the error in measurements of a homogenous magnetic field of known orientation using a Gauss-meter that uses a Hall-effect probe. The uncertainty in the measurements reported by the Gauss-meter are given the user's manual. Since the probe is held by hand, there will also be some uncertainty due to the orientation of the probe with respect to the magnetic field.
Let
[itex]B_{hom}=[/itex]The homogeneous mag field
[itex]B_{m}=[/itex] The field value measured by the instrument
[itex]\theta=[/itex] The angle between [itex]\vec{B}_{hom}[/itex] and the direction normal to the surface of the hall element.
The component of the magnetic field that gives rise to the Hall potential in the probe is perpendicular to the surface of the element, so,
[tex]B_{m}=B_{hom}\cos\theta\rightarrow B_{hom}= \frac{B_{m}}{\cos\theta}[/tex]
There is error in both [itex]B_{m}[/itex] and [itex]\theta[/itex]. Through error propagation, the error in [itex]B_{hom}[/itex] will be,
[tex]\delta B_{hom}= \sqrt{ \left (\frac{\partial B_{hom}}{\partial B_{m}}\delta_{ B_{m}} \right )^{2} + \left ( \frac{\partial B_{hom}}{\partial \theta}\delta_\theta\right )^2}[/tex]
[tex]\rightarrow \delta B_{hom}= B_{m}\sqrt{ \left ( \frac{\delta_{B_{m}}} {B_{M}} \right )^{2}+ \tan^{2}\left (\theta \right )\delta_{\theta}^{2}} [/tex]
Here is where the ambiguity comes in, Theta is measured as zero by the person measuring the magnetic field. At zero, the term due to error in theta vanishes leaving only the term due to uncertainty in B_m. This is problematic. The formula gives no information about the error due to theta at the data point where I need the information. My question is how do I deal with this type of ambiguity? Taylor expansion maybe? Thank you for your replies.
There are two answers to this. The first is that the equations are telling you that the final error is pretty insensitive to smallish errors in theta if theta is near 0. Beyond that, you may nevertheless want to estimate what happens for larger errors. For that, yes, you will need an expansion which keeps smaller terms, like cos(δθ) ≈ 1 - δθ2/2.
cool, thank you.
Related to Estimating Error in Meas. of Homog. Mag Field w/ Hall Effect Probe
What is a Hall effect probe?
A Hall effect probe is a type of sensor used to measure magnetic fields. It works by using the Hall effect, which is the generation of a voltage difference across an electrical conductor when it is placed in a magnetic field.
Why is it important to estimate error in measuring homogeneous magnetic fields?
Estimating error is important because it allows us to understand the accuracy and reliability of our measurements. In the case of measuring homogeneous magnetic fields, errors can arise from various sources such as sensor calibration, environmental interference, and human error. By estimating the error, we can determine the precision and validity of our data.
What factors can affect the accuracy of measurements with a Hall effect probe?
Several factors can affect the accuracy of measurements with a Hall effect probe. These include the orientation of the probe with respect to the magnetic field, the temperature of the probe, and the sensitivity and calibration of the probe. Additionally, external factors such as electromagnetic interference and noise can also impact the accuracy of measurements.
How is error calculated in measuring homogeneous magnetic fields with a Hall effect probe?
Error in measuring homogeneous magnetic fields with a Hall effect probe is typically calculated by taking multiple measurements and computing the average value. The difference between each measurement and the average value is then used to determine the error. This error can be expressed as a percentage or in terms of standard deviation.
What are some methods for reducing error in measurements with a Hall effect probe?
To reduce error in measurements with a Hall effect probe, it is important to properly calibrate the sensor, minimize external interference, and ensure the probe is oriented correctly with respect to the magnetic field. Additionally, taking multiple measurements and averaging the results can also help to reduce error. Regular maintenance and calibration of the probe can also improve the accuracy of measurements over time.
