Estimating the force of he water on the dutch boys finger
In summary: You just need a rough estimate. In summary, the question asks for an estimation of the force of the water on the little Dutch boy's finger as he holds it in the leaking dike to save Holland. The pressure on his finger was calculated to be 125,800 Pa using the equation P = p0+pgh. To convert this pressure to force, the area of the boy's finger must be estimated. It is suggested to measure the diameter of one's own finger and approximate it as a circle, or to use a string and divide its length by Pi to get the diameter. The area of a circle can then be calculated using its diameter, and this value can be used to convert the pressure to force. This estimation does not
Nellen2222
55
The little dutch boy saved HOlland by sticking his finger in the leaking dike. if the water level was 2.5m above his finger, estimate the force of the water on his finger
I calculated the pressure on his finger by P = p0+pgh = 125,800 Pa.
But i have no idea what to do now.
Pressure is Force/Area. You must estimate the area of the boy's finger and use this to convert the pressure to force.
how do i do that..
Nellen2222 said:
how do i do that..
Just look at the units:
[itex]\displaystyle \frac{Force}{Area} × Area = Force[/itex]
To estimate the area of the boy's finger, I would just measure my own finger. Measure the diameter of your finger and approximate it as a circle.
Nellen2222, Should you use absolute pressure or gauge pressure ρgh? (Edit: forget my question, I was thinking the question was asking what force the boy would need to exert to hold the water back.)
how do i do that..
Estimate the diameter of his finger. Assume it's circular?
Nellen2222 said:
how do i do that..
Assume your finger is approximately a cylinder. Can you guess what the diameter of your finger is? Mine is about 1 cm. But if you can't even estimate that, wrap a string around your finger, and measure its length (after unwrapping it again). Then divide by Pi to get the diameter. Do you know how to get the area of a circle if you know its diameter? Your teacher is not looking for the exact answer, so you don't have to determine the diameter very accurately.
FAQ: Estimating the force of he water on the dutch boys finger
How is the force of water on the Dutch boy's finger estimated?
The force of water on the Dutch boy's finger is estimated by using the formula F = ρghA, where F is the force, ρ is the density of water, g is the acceleration due to gravity, h is the height of the water column, and A is the surface area of the finger.
What factors affect the force of water on the Dutch boy's finger?
The force of water on the Dutch boy's finger is affected by the density of water, the acceleration due to gravity, the height of the water column, and the surface area of the finger. Other factors such as the speed and direction of the water flow may also have an impact.
Can the force of water on the Dutch boy's finger be accurately estimated?
Yes, the force of water on the Dutch boy's finger can be accurately estimated using the formula F = ρghA and taking into account all relevant factors. However, there may be some margin of error due to external factors such as variations in water density or flow speed.
Why is it important to estimate the force of water on the Dutch boy's finger?
Estimating the force of water on the Dutch boy's finger is important for understanding the potential impact of water on different objects or structures. It can also help in designing structures that can withstand the force of water, such as dams or flood barriers.
Are there any real-life applications of estimating the force of water on the Dutch boy's finger?
Yes, there are many real-life applications of estimating the force of water on the Dutch boy's finger. Some examples include designing and building flood control systems, calculating the force of water on ships and boats, and predicting the impact of water on coastal structures during storms or tsunamis.
