Estimating the Gradient of a Graph: Student's Attempt
  • Thread starter Thread starter chwala
    Gradient Graph
The discussion centers on a student's attempt to estimate the gradient of a graph using points (1,2) and (0.9,1.8), resulting in a gradient of m=2, which is significantly different from the correct estimate of m=1.5. The evaluator notes that (0.9,1.8) is visibly below the tangent line, indicating a potential error in the student's selection of points. There is a consensus that while the calculation based on the student's points is mathematically correct, the choice of points does not accurately reflect the tangent line, warranting a loss of marks. The conversation emphasizes the importance of selecting appropriate points on the graph to minimize errors in gradient estimation. Overall, the need for clearer guidance on point selection is highlighted to improve student accuracy in future assessments.
chwala
Draw the tangent to the curve at the point where ##x=1##. Use this tangent to claculate an estimate to the gradient of ##y=2^x## when ##x=1##
gradient
Ok this is a question that i am currently marking...the sketch is here;
In my mark scheme i have points ##(1,2)## and ##(3,5)## which can be easily picked from the graph to realize an estimate of ##m=1.5## where ##m## is the gradient ...of course i have given a range i.e ##1.6≥m≥1.2##
Now to my question. hmmmmm :wink:
A student picked the points ##(1,2)## and ##(0.9,1.8)## getting ##m=2## ...the difference from actual is quite big...but the points are picked from their straight line...am i missing something here...
Actual gradient using differentiation would be given by;
##\dfrac{dy}{dx}= 2^x\ln 2##
##\dfrac{dy}{dx}[x=1]= 2^1\ln 2=1.386##
Your insight welcome.
Is the tangent line drawn by the student, or is it printed on the paper?
In any case, I think (0.9, 1.8) is visibly below the tangent line in the picture.
Drawn by the student...we would not expect the students to draw this accurately 100%. How do i deal with this? should i increase range of expected values? my thinking is; i cannot penalise the student for having picking those points from their tangent line...and the calculation as per their picked points is correct.
I dont think (0.9, 1.8) is on their tangent line: it's visibly below it. That should result in some loss of marks. If they'd gone with (0.9, 1.85) then they might have a better case.
I just checked the accurate graph on desmos...points ##(0.9,1.85)## would have been fine...
Thanks...i agree...i will emphasis the need to try and pick obvious points on the graphs to mitigate this. Cheers great weekend mate!
An additional comment: as a physicist, I would emphasize the large error introduced by picking such a small ##\Delta x##: any error in ##\Delta y## as read off from the graph is multiplied by 10 !
Notice in general, unless your function is itself linear to start with, the approximation is only local. But if youre just given the point (1,2), there are infinitely-many lines that go through it. The point (0.9, 1.8) defines just one of infinitely-many such lines. Not sure if this addresses your question.
Not sure ...we need points that are on the tangent line and as discussed above, it's clear that ##(0.9,1.8)## is not a point on the tangent line to the given curve ##y=2^x##.
Do you mean at the point (1,2)?
Yes.
chwala said:
Yes.
Well, the points (1,2) and (0.9, 1.8) defines the line y2=2x, which contrasts with the line
y1-1=1.386(x-2).
Maybe a bound/estimate for |y1-y2| would help explain why the choice of (0.9, 1.8) was not as good. Additionally , comparing it with the choice of {(1,2),(3,5)} which would define the line y3-2=2(x-1).
Maybe we can find a generic value for
|y-y1|, for y=mx+b.
Hope I'm not too far of.
