Estimating the mass of our galaxy, and the number of stars in our galaxy
The formula is T^2 = (4pi^2/G) * r^3.In summary, the previous thread discussed converting 2*10^8 years to seconds and then went on to explain how to plug in the period and radius (which was converted to meters) into Kepler's third law formula ((4pi^2)r^3)/G*T^2). This formula is derived from Kepler's third law and can be used to calculate the period (T) of an orbit given the radius (r) and gravitational constant (G).
aj_17
The Sun rotates about the center of the Milky Way Galaxy at a distance of about 30000 light-years from the center
(1ly=9.5×10^15m).
Part A
If it takes about 200 million years to make one rotation, estimate the mass of our Galaxy. Assume that the mass distribution of our Galaxy is concentrated mostly in a central uniform sphere.
Part B
If all the stars had about the mass of our Sun (2×10^30kg), how many stars would there be in our Galaxy?
((4pi^2)r^3)/G*T^2)
A previous thread outlined the problem with a correct answer, however I don't understand where they got the formulas from. Here are the steps I've taken so far:
1. Convert 2*10^8 years to seconds = 6.3072*10^15 seconds (period,T)
2. The previous thread then went on to say you plug period and radius (which the thread said was 2.85*10^20, how is this found?) into the "formula":
((4pi^2)r^3)/G*T^2) How do you arrive at this formula?
Looks OK.
You need to get into a consistent set of units. Since you will probably use G in MKS units, you need to convert the radius in light-years into meters.
into the "formula":((4pi^2)r^3)/G*T^2) How do you arrive at this formula?
It's from Kepler's third law.
Related to Estimating the mass of our galaxy, and the number of stars in our galaxy
1. How do scientists estimate the mass of our galaxy?
Scientists use a variety of methods to estimate the mass of our galaxy. One method is to measure the rotational velocity of stars in the outer regions of the galaxy and use this to calculate the mass of the galaxy. Another method is to study the gravitational effects of the galaxy on nearby objects, such as dwarf galaxies or globular clusters.
2. What is the estimated mass of our galaxy?
The estimated mass of our galaxy is approximately 1-2 trillion solar masses. This includes all of the stars, gas, and dark matter within the Milky Way.
3. How many stars are estimated to be in our galaxy?
There are approximately 100-400 billion stars in our galaxy. This estimate is based on observations and models of the Milky Way.
4. How accurate are these estimates of mass and number of stars in our galaxy?
The estimates of the mass and number of stars in our galaxy are constantly being refined and improved as new data and techniques become available. However, there is a margin of error in these estimates, and they are subject to change as our understanding of the galaxy evolves.
5. How does the mass and number of stars in our galaxy compare to other galaxies?
The mass and number of stars in our galaxy are considered to be average compared to other galaxies in the universe. While there are some galaxies that are significantly larger and more massive, there are also many smaller galaxies with fewer stars. Overall, the Milky Way is a typical spiral galaxy in terms of its size and composition.
