MHB Estimating variance of Poisson random variable
The discussion focuses on estimating the mean and variance of a Poisson random variable with a mean of 5 using R. A random sample is generated, and the expected value of the square root of the sample is calculated, yielding a value close to the theoretical square root of 5. The variance of the square root is estimated using a specific formula, resulting in a value of approximately 0.2230577, which raises questions about its accuracy. It is clarified that the variance cannot be zero, as this would imply a constant random variable. The speaker concludes that calculating the expected value of the square root requires a more complex approach, suggesting that the variance should be around 1/4.
Jameson
Insights Author
MHB
I am trying to use a generated random sample in R to estimate the mean and variance for a Poisson random variable. The first one is a Poisson random variable with mean 5.
To estimate the above I generate a random sample in R with the following code:
Code:
P5 <- rpois(100,5)
Given the above I want to find $E[\sqrt{X}]$. Easy enough. To estimate the expected value of the square of X, I can take the square root of the sample and divide by 100.
Code:
mean(sqrt(P5))
The above comes out to be 2.292802 and $\sqrt{5}=2.2346$ so all looks good.
Now I want to estimate the $\text{Var}[\sqrt{X}]$. I can use the following formula to help: $\text{Var}[\sqrt{X}]=E[X]-E[\sqrt{X}]^2$
Code:
sum((P5))/100-(sum(sqrt(P5))/100)^2
From the above I get 0.2230577 but to honest, I can't figure out what the ideal value should be. Plugging in $\lambda$ into the variance formula is seems like this should be $\lambda-\sqrt{\lambda}^2=0$.
Any insight as to how to get this value?
Ok so after thinking about this for more than 1 second a couple of things are clearer:
1) The variance is obviously not 0. I knew that before but it seems so hilariously absurd now as that would mean the value of the random variable is always a constant.
2) To calculate $E[\sqrt{X}]$ I need to use the full formula and not just "plug in". So this would be: $$E[\sqrt{x}]=\sum_{x=0}^{\infty}\sqrt{x} \cdot \frac{\lambda^x e^{-\lambda}}{x!}$$. This most likely doesn't have a nice cancellation that $E[X]$ does and my guess would be there is no closed solution to this expectation. From what I have found the variance should indeed be something close to 1/4, so all is looking good. :)
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
