Estimation error from estimation quantile of normal distribution
In summary, the conversation discusses estimating the probability that a random variable, assumed to be normally distributed, exceeds a quantile based on a limited number of observations. The group suggests finding estimates of the mean and standard deviation to improve accuracy. They also mention the use of t-distributions and the Central Limit Theorem for large sample sizes. It is also mentioned that the purpose of the project may be to analyze the distribution of a specific estimator.
Derk
Hi guys,
For my (master) project I am trying to find the probability that a random variable, which is normally distributed, exceeds a quantile that is estimated by a limited number of observations. See attached for my attempt.
- Is it correct?
- How to incorporate the fact that the mean and variance of the normal distribution are unknown in reality?
Thanks in advance!
  • Derivation_quantile.pdf
Why do you estimate it that way if you know your variable has a normal distribution? Find estimates of the mean and the standard deviation, calculate the quantile based on that. It will give you much better estimates especially for large deviations from the mean.
I agree with mfb: If/when you don't know the standard deviation from a normal population, then the sample mean ##x_s ## is t-distributed as ( for a two-sided) ##( x_s- t_{ \alpha/2}SE, x_s+ t_{\alpha /2} SE )## where SE is the standard error and ## \alpha ## is the confidence level. Other statistics have different distributions. Do you have any specific one in mind? If you are computing the sampling mean and your sample is large-enough ( n>30 usually; n>= 40 for more accuracy) then you can use the CLT to assume normality.
It may be that the purpose of @Derk 's project is not to find an optimal method of estimating a quantile, but rather to work out the distribution of a particular estimator. If he were doing a masters project in engineering, we'd expect something practical, but a mathematical project can be an "academic exercise".
Related to Estimation error from estimation quantile of normal distribution
1. What is estimation error and how does it relate to the estimation quantile of a normal distribution?
Estimation error refers to the difference between the true value of a parameter and the estimated value based on a sample. The estimation quantile of a normal distribution is a measure of the uncertainty or variability in the estimated value. A lower estimation quantile indicates a more precise estimate with less error, while a higher estimation quantile indicates a less precise estimate with more error.
2. How do you calculate the estimation error from the estimation quantile of a normal distribution?
The estimation error can be calculated by finding the difference between the true value of the parameter and the estimated value, and then dividing by the estimation quantile. This ratio will give you the magnitude of the estimation error, with a larger value indicating a larger error.
3. Can estimation error be eliminated completely when using the estimation quantile of a normal distribution?
No, it is not possible to completely eliminate estimation error. No matter how precise the estimate, there will always be some level of error due to the inherent variability in the data. However, using a smaller estimation quantile can reduce the amount of error and improve the accuracy of the estimate.
4. How can the estimation quantile of a normal distribution be used to assess the quality of an estimate?
The estimation quantile can be used to assess the precision and accuracy of an estimate. A lower estimation quantile indicates a more precise and accurate estimate, while a higher estimation quantile indicates a less precise and accurate estimate. Comparing the estimation quantiles of different estimates can help determine which one is more reliable.
5. Are there any limitations to using the estimation quantile of a normal distribution to measure estimation error?
One limitation is that the estimation quantile assumes a normal distribution of the data, which may not always be the case. Additionally, it only measures the variability in the estimate and does not take into account any systematic bias in the data. It is important to consider other measures of error and assess the assumptions of the normal distribution before relying solely on the estimation quantile for evaluating estimation error.
