Estimation of material loss through electrical resistivity
In summary: Measurement of vibration levels can be simple or very sophisticated .A lot of work has been done on monitoring tool wear by analysing the broad spectrum 'sound' created by the cutting process .In summary, electrical resistivity can be used to estimate the material loss of tools in cutting machines. This would depend on the measurements being taken at the same temperatures and the sensitivity of the equipment. Tool wear is most commonly monitored by measuring vibration levels or tool edge profile.
serbring
271
Hi all,
I'm doing a little project about the wear of materials for tools for cutting machines.Yesterday, I was reading wikipedia page about electrical resistivity and I thought if it might be possible to evaluate the estimate the material loss of the tool through the measure of electrical resistivity. Might be possible or it is just "pure fantasy"? :)
serbring said:
Hi all,
Sounds reasonable without thinking about it too hard, the measurements would need to be taken at the same temperatures to ensure accurate results. It would also depend on how much material you lose between measurements and the sensitivity of your equipment. (Changes in resistance would need to be larger than the uncertainties in your measurement to draw anything accurate from it) It also wouldn't tell you where you lost the material, without some additional design if that mattered. Corrosion would be a concern, as well.
Can you provide additional context? What kind of tool? How much material are you losing from rough estimates? What kind of time frames for wear are you talking about?
Not entirely fantasy but difficult to implement in most practical situations and very prone to giving false results .
Tool wear is most commonly monitored by some of these methods :
In cutting cycle by measurements of input power , vibration level , temperature rise or tool shank reaction force .
Out of cutting cycle by measurements of tool edge profile , workpiece surface finish or workpiece dimensional error .
Likes Student100
You're on right, corrosion and temperature is something should be considered. When the tool should be changed, the material loss is about the 10% of the total tool weight and it usually occurs after a year.
I was thinking of a solution for tillage tools but soil conditions (moisture, compaction) markedly affect the input power and vibrations are usually pretty high.
Related to Estimation of material loss through electrical resistivity
1. What is electrical resistivity?
Electrical resistivity is the measure of a material's ability to resist the flow of electric current. It is typically represented by the symbol "ρ" and is measured in ohm-meters (Ω·m).
2. How is material loss estimated through electrical resistivity?
Material loss can be estimated through electrical resistivity by measuring the change in resistivity over time. This change is often caused by corrosion or degradation of the material, which can be quantified through resistivity measurements.
3. What factors affect the accuracy of estimating material loss through electrical resistivity?
The accuracy of estimating material loss through electrical resistivity can be affected by factors such as the type of material, the environment it is exposed to, and the type of measurement equipment used. Other factors, such as temperature and humidity, can also impact the accuracy of measurements.
4. What are some common methods for measuring electrical resistivity?
There are several common methods for measuring electrical resistivity, including the four-probe method, the two-probe method, and the van der Pauw method. Each method has its own advantages and limitations, and the choice of method may depend on the specific application and material being measured.
5. How can estimating material loss through electrical resistivity be useful for industries?
Estimating material loss through electrical resistivity can be useful for industries in many ways. It can help identify potential areas of corrosion or degradation in equipment or structures, allowing for early detection and prevention of costly damage. It can also aid in quality control and monitoring of materials, ensuring they meet safety and performance standards. Furthermore, it can help improve the efficiency and lifespan of materials, leading to cost savings and increased productivity.
