Euclid's Formula as a test for sufficiency
In summary, the conversation discusses whether a right triangle with integer sides is impossible if one of the sides cannot be derived from Euclid's formula for Pythagorean triples. It is concluded that while the formula covers all possible right triangles, there can be cases where the sides do not follow the formula but still result in a triangle with integer sides. This depends on the values of m, n, and k in the formula.
e2m2a
359
If anyone side of a triangle cannot be derived from Euclid’s formula for pythagorean triples, is this sufficient to prove that a right triangle with integer sides is impossible?
For example, let's take the leg expressed by k2mn in Euclid's formula,, where k,m,n, are integers. If one of the sides of a triangle is expressed by prime and non-integer factors that do not conform to k2mn, is this sufficient to prove that the other remaining sides will never form a right triangle with integer sides?
Mathematics news on Phys.org
They exist, you can't prove that they are impossible.
If none of the squares of a side is the sum of squares of the other two sides then this particular triangle won't be a right triangle.
How do you know the side is not one of the other two sides in Euclid's formula? 3 and 5 cannot be written as 2mn, but clearly both can be in such a triangle (3,4,5).
Maybe I don't understand what you are implying. Are you saying that right triangles with integer sides are possible that do not fall under the net of Euclid's formula?
No, the formula covers all, but your first post had a different question.
Ok. Let me restate my inquiry. Suppose we have two line segments and it is given that they each touch at one end, and that they are perpendicular to each. Suppose one line segment can be expressed by 2mnk, where m > n and m,n, and k are integers. Suppose the second line segment can be expressed by m^sq - n^sq. Does it follow by citing Euclid's formula that a line segment connecting the open ends of the two segmens must be equal to m^2 + n^2?
And if this is true, can we assert the following. Suppose the first line segment equals 2mnk as before, but the second line segment does not equal to m^2 - n^2, but some other integer value not equal to m^2 - n^2. Does it follow from Euclid's formula that a line segment connecting the open ends of these two segments can never be an integer?
sq=2?
From Pythagoras we know the third line will have a squared length that is the sum of the other two squared lengths. ##(2mnk)^2 + (k(m^2-n^2))^2 = k^2 (m^2+n^2)^2## which is a square. You missed the k for two lengths.
That depends on how you define m and n. For a given first line you can find m,n such that the second line doesn't have length k(m^2 - n^2) even if it is part of a triple with integer side lengths.
As an example, consider the triangle 3,4,5. Clearly 4 can be expressed as 2mnk where k=2, m=1, n=1. The the second side (3) is not equal to k(m^2 - n^2), but you still have a triangle with integer side lengths. You (well, I did) just made a poor choice of m,n,k. If there is no combination of k,n,m such that the two sides can be expressed in this way then the third side length is not an integer.
Do you mean ##m^2 - n^2##? If so, what you wrote is an unusual and very confusing way to write this.
FAQ: Euclid's Formula as a test for sufficiency
What is Euclid's Formula as a test for sufficiency?
Euclid's Formula is a mathematical equation used to determine the sufficiency of a set of numbers in representing a right triangle. It states that if three positive integers a, b, and c satisfy the equation a^2 + b^2 = c^2, then they can be the lengths of the sides of a right triangle.
How is Euclid's Formula used in mathematics?
Euclid's Formula is used as a test for sufficiency in determining if a set of numbers can represent the sides of a right triangle. It is also used in various geometric proofs and constructions involving right triangles.
What is the significance of Euclid's Formula?
Euclid's Formula is significant because it provides a simple and efficient way to determine if a set of numbers can form a right triangle. It is also a fundamental concept in geometry and has been used for centuries in various mathematical applications.
Can Euclid's Formula be used to prove the Pythagorean Theorem?
Yes, Euclid's Formula can be used to prove the Pythagorean Theorem, which states that in a right triangle, the square of the length of the hypotenuse is equal to the sum of the squares of the other two sides. This can be shown by substituting a and b with the lengths of the legs of a right triangle and c with the length of the hypotenuse in Euclid's Formula.
Are there any limitations to using Euclid's Formula as a test for sufficiency?
Yes, there are limitations to using Euclid's Formula as a test for sufficiency. It can only be used for right triangles and cannot be applied to other types of triangles. Additionally, there may be cases where a set of numbers satisfies the formula but does not represent a valid right triangle, such as when the numbers are not positive integers.
