MHB Eugene's question via Facebook about a Differential Equation
The differential equation $\frac{\mathrm{d}y}{\mathrm{d}x} = 3\,\sqrt{4 - y^2}$ is solved by separating variables and integrating, leading to the expression $y = 2\sin(3x + C)$. The initial condition $y(0) = 2$ helps determine the constant $C$, which is found to be $\arcsin(1) = \frac{\pi}{2}$. Thus, the final solution is $y(x) = 2\sin(3x + \frac{\pi}{2})$. The discussion highlights the importance of correctly applying initial conditions in solving differential equations.
Prove It
MHB
Solve $\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} = 3\,\sqrt{4 - y^2} \end{align*}$ given that $\displaystyle \begin{align*} y\left( 0 \right) = 2 \end{align*}$
This equation is separable...
$\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x}&= 3\,\sqrt{4 - y^2} \\ \frac{1}{\sqrt{4 - y^2}}\,\frac{\mathrm{d}y}{\mathrm{d}x} &= 3 \\ \int{ \frac{1}{\sqrt{4 - y^2}}\,\frac{\mathrm{d}y}{\mathrm{d}x} \,\mathrm{d}x} &= \int{ 3\,\mathrm{d}x} \\ \int{ \frac{1}{\sqrt{4 - y^2}}\,\mathrm{d}y} &= 3\,x + C_1 \end{align*}$
Now let $\displaystyle \begin{align*} y =2\sin{(t)} \implies \mathrm{d}y = 2\cos{(t)}\,\mathrm{d}t \end{align*}$
$\displaystyle \begin{align*} \int{\frac{1}{\sqrt{ 4 - \left[ 2\sin{(t)} \right] ^2} } \,2\cos{(t)} \, \mathrm{d}t } &= 3\,x + C_1 \\ \int{ \frac{ 2\cos{(t)} }{ \sqrt{4 - 4\sin^2{(t)} } }\,\mathrm{d}t} &= 3\,x + C_1 \\ \int{ \frac{2\cos{(t)}}{\sqrt{4\left[ 1 - \sin^2{(t)} \right] } } \,\mathrm{d}t} &= 3\,x + C_1 \\ \int{ \frac{2\cos{(t)}}{\sqrt{4\cos^2{(t)} }}\,\mathrm{d}t} &= 3\,x + C_1 \\ \int{ \frac{2\cos{(t)}}{2\cos{(t)}}\,\mathrm{d}t} &= 3\,x + C_1 \\ \int{1\,\mathrm{d}t} &= 3\,x + C_1 \\ t + C_2 &= 3\,x + C_1 \\ t &= 3\,x + C, \textrm{ where } C = C_1 - C_2 \\ \arcsin{ \left( \frac{y}{2} \right) } &= 3\,x + C \\ \frac{y}{2} &= \sin{ \left( 3\,x + C \right) } \\ y &= 2\sin{ \left( 3\,x + C \right) } \end{align*}$
and since $\displaystyle \begin{align*} y \left( 0 \right) = 2 \end{align*}$
$\displaystyle \begin{align*} 2 &= \sin{ \left[ 3 \left( 0 \right) + C \right] } \\ 2 &= \sin{(C)} \\ C &= \arcsin{ \left( 2 \right) } \end{align*}$
Thus $\displaystyle \begin{align*} y = 2\sin{ \left[ 3\,x + \arcsin{ \left( 2 \right) } \right] } \end{align*}$
Mathematics news on Phys.org
Prove It said:
...and since $\displaystyle \begin{align*} y \left( 0 \right) = 2 \end{align*}$
Just a minor quibble...you want:
$$2=2\sin(3(0)+C)\implies C=\arcsin(1)$$
Hence:
$$y(x)=2\sin\left(3x+\arcsin(1)\right)$$
Hence:
This is why I shouldn't tutor at 1am hahaha. And of course, $\displaystyle \begin{align*} \arcsin{(1)} = \frac{\pi}{2} \end{align*}$ :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
