Euler Lagrange equation of motion
In summary: Anyway, the OP did try to obtain the derivatives for himself, but made some errors. I admit maybe I should have not written so much detail (which does not matter anyway, since I did the wrong calculation!).
bobred
173
Find the equations of motion for both r and [itex]\theta[/itex] of
5E%7B2%7D%20%5Cright%29%5Cdot%7Br%7D%5E%7B2%7D+r%5E%7B2%7D%5Cdot%7B%5Ctheta%7D%20%5Cright%29-mgH.png
My problem is taking the derivative wrt time of
ex?%5Cfrac%7B%5Cpartial%20L%7D%7B%5Cpartial%20%5Cdot%7B%5Ctheta%7D%7D=mr%5E2%5Cdot%7B%5Ctheta%7D.png
and
[itex]\dfrac{\partial\mathcal{L}}{\partial\dot{r}}=m \dot{r} \left( 1 + \left( \dfrac{\partial H}{\partial r}\right)^2 \right)[/itex]
So
%7B%5Ctheta%7D%7D%20%5Cright%29=2mr%5Cdot%7Br%7D%5Cdot%7B%5Ctheta%7D+mr%5E2%5Cddot%7B%5Ctheta%7D.png
I think this is correct. I have the solution to the second expression but I am unsure how it was found
[itex]
m \ddot{r} \left( 1 + \left( \dfrac{\partial H}{\partial r}\right)^2 \right) + 2 m \dot{r}^2 \dfrac{\partial H}{\partial r}\dfrac{\partial^2 H}{\partial r \partial t}
[/itex]
The first part of this expression is fine it is the second part I am unsure of.
Please specify what ##H## is a function of.
HI, sorry H(r).
So if H is only a function of r, the only possible derivative of H is the total derivative wrt r. Since r depends on t, the derivative wrt t is given by the chain rule. This also goes for dH/dr, which is also a function of r. The partial derivative of H wrt t does not make sense if H does not depend explicitly on t.
bobred said:
HI, sorry H(r).
So, if we write ##K(r) = (\partial H(r) /\partial r)^2## (which is just some computable function of ##r##) you have
[tex] {\cal{L}} = \frac{1}{2} m \left((1+ K(r)) \dot{r}^2 + r^2 \dot{\theta} \right) - mgH(r) [/tex]
Thus,
[tex] {\cal{L}}_r \equiv \partial {\cal{L}} /\partial r = \frac{1}{2}m \left( K'(r) \dot{r}^2 + 2 r \dot{\theta} \right) - m g H'(r) [/tex]
so
[tex] \frac{d}{dt} {\cal{L}}_r = \frac{1}{2} m \left( K''(r) \dot{r}^3 + K'(r) 2 \dot{r} \ddot{r} + 2 \dot{\theta} \right) - mg H''(r) \dot{r} [/tex]
If ##H## does not depend explicitly on ##t## there should be no ##\partial H/\partial t## anywhere.
Thus,
so
This, although correct, is not relevant for the Euler-Lagrange equations which contain what you would call ##d\mathcal L_{\dot r}/dt##. Also, please allow the OP to try to do the derivatives for himself.
You are right. Anyway, the OP did try to obtain the derivatives for himself, but made some errors. I admit maybe I should have not written so much detail (which does not matter anyway, since I did the wrong calculation!).
FAQ: Euler Lagrange equation of motion
1. What is the Euler Lagrange equation of motion?
The Euler Lagrange equation of motion is a mathematical equation used to describe the motion of a system. It is derived from the principle of least action, which states that the path taken by a system between two points in time is the one that minimizes the action, a quantity that represents the total energy of the system.
2. How is the Euler Lagrange equation of motion derived?
The Euler Lagrange equation of motion is derived by taking the derivative of the action with respect to the system's variables, such as position, velocity, and time. This results in a set of differential equations that describe the system's motion.
3. What types of systems can the Euler Lagrange equation of motion be applied to?
The Euler Lagrange equation of motion can be applied to a wide range of systems, including classical mechanics systems, quantum mechanical systems, and systems in relativity. It is particularly useful in systems with many degrees of freedom, such as a system of particles.
4. What are the advantages of using the Euler Lagrange equation of motion?
The Euler Lagrange equation of motion provides a concise and elegant way to describe the dynamics of a system. It also allows for a more intuitive understanding of the system's behavior and can be applied to a variety of systems, as mentioned before.
5. Are there any limitations to the use of the Euler Lagrange equation of motion?
While the Euler Lagrange equation of motion is a powerful tool, it does have some limitations. It assumes that the system is conservative, meaning that there is no dissipation of energy. It also does not take into account any external forces acting on the system. Additionally, it may not be applicable to systems with complex or chaotic behavior.
