Euler Lagrange Equation Question
In summary: If you are holding x constant (as you should be in a partial derivative with respect to y) then why would you also be holding y constant in the full derivative?In summary, for the given function f(y,y',x) = 2yy' + 3x2y and y(x) = 3x4 - 2x +1, we can calculate ∂f/∂x = 6xy = 6x(3x4 - 2x +1) and df/dx = (3x2 + 2(y * d/dy(y') + y')) * (12x3 - 2). The full derivative is not simply the product of the partial derivative and
HiggsBrozon
Consider the function f(y,y',x) = 2yy' + 3x2y where y(x) = 3x4 - 2x +1. Compute ∂f/∂x and df/dx. Write both solutions of the variable x only.
Euler Equation: ∂f/∂y - d/dx * ∂f/∂y' = 0
Would I first just find ∂f/∂y and ∂f/∂y' as follows:
∂f/∂y = 2y' + 3x2
∂f/∂y' = 2y
and then insert y(x) and y'(x) into my two equations for ∂f/∂y and ∂f/∂y':
y(x) = 3x4 - 2x +1
y'(x) = 12x3 - 2
→ ∂f/∂y = 2(12x3 - 2) + 3x2
→ ∂f/∂y' = 2(3x4 - 2x +1)
This is where I begin to get lost. Would I plug these values into my Euler equation to find an expression for df/dx and ∂f/∂x?
I would attempt this but I want to see if I'm headed in the right direction or not first. Any help would be much appreciated.
You don't need to find those at all. You don't need to use the Euler-Lagrange equations either. Just calculate the things they ask for in the question. I think they are just testing your knowledge of how to do partial differentiation and the full derivative.
Thanks for you response. I feel as if I made this problem more complicated than it should.
For ∂f/∂x:
and df/dx:
df/dx = ∂f/∂y * dy/dx
= d/dy(3x2y + 2yy') * (12x3 - 2)
= (3x2 + 2(d/dy(yy'))) * (12x3 - 2)
However I'm a bit confused on how to take the derivative of d/dy(y')
Would I just treat y' as a fraction and cancel out dy's like so: y * d/dy(dy/dx) = d/dx * y = y'
I think your answer for ∂f/∂x is correct. But I don't agree with your answer for df/dx. The line: df/dx = ∂f/∂y * dy/dx I think is not right. This is not the correct expression for the full derivative. p.s. you can realize this by thinking what is being held constant for ∂f/∂y
Your approach is correct so far. To find ∂f/∂x and df/dx, you would plug in the values for ∂f/∂y and ∂f/∂y' that you have calculated into the Euler equation:
This will give you an expression for df/dx. Then, you can use the chain rule to express df/dx in terms of x only, using the given function y(x). This will give you the final solution for df/dx in terms of x only. Similarly, you can use the chain rule to express ∂f/∂x in terms of x only, using both y(x) and y'(x). This will give you the final solution for ∂f/∂x in terms of x only. Remember to simplify your expressions as much as possible to get a final solution.
Related to Euler Lagrange Equation Question
1. What is the Euler-Lagrange equation?
The Euler-Lagrange equation is a mathematical equation that is used to find the stationary points of a functional. It is commonly used in the field of calculus of variations.
2. How is the Euler-Lagrange equation derived?
The Euler-Lagrange equation is derived by taking the derivative of the functional with respect to the function that minimizes the functional. This results in a second-order ordinary differential equation.
3. What is the significance of the Euler-Lagrange equation?
The Euler-Lagrange equation is significant in that it provides a way to find the function that minimizes a given functional. This is useful in many areas of science and engineering, including physics, economics, and optimization problems.
4. Can the Euler-Lagrange equation be used for both single-variable and multi-variable functions?
Yes, the Euler-Lagrange equation can be used for both single-variable and multi-variable functions. In the case of multi-variable functions, the equation is known as the Euler-Lagrange equation for multiple variables.
5. Are there any limitations to using the Euler-Lagrange equation?
While the Euler-Lagrange equation is a powerful tool for finding the stationary points of a functional, it does have some limitations. It may not always be possible to find an explicit solution to the equation, and it may also fail to find all possible solutions.
