A Euler vs. Tait (steady precession vs... what?)
  • A
  • Thread starter Thread starter Trying2Learn
    Euler Precession
Euler angles and Tait-Bryan angles are two approaches to studying body rotations, with key differences in their axis representation. Tait-Bryan angles involve distinct rotations about three axes, while Euler angles use the same axis for the first and third rotations. In Euler angles, the concept of "Steady Precession" describes a scenario with constant precession and spin rates. The analogous case in Tait-Bryan angles is known as "Steady Turn," where the yaw rate is constant, pitch rate is zero, and roll rate is constant. This term is frequently applied in aviation and aerospace contexts.
Trying2Learn
TL;DR Summary
what is the analogue of steady precession when using the Tait -Bryan angles
Good Morning
When one studies body rotations, there are two general approaches one uses: Euler Angles vs. Tait-Bryan Angles.
The significant difference is that:
  • Tait–Bryan angles represent rotations about three distinct axes (e.g. x-y-z, or x-y′-z″): Yaw, Pitch, Roll
  • Euler angles use the same axis for both the first and third elemental rotations (e.g., z-x-z, or z-x′-z″): Precession, Nutation, Spin
With Euler angles, there is a special case of STEADY PRECESSION: precession rate is constant, nutation rate is 0, spin rate is constant.
Is there a NAME for the analogous case, when modeling with Tait? Yaw rate is constant, pitch rate is 0, roll rate is constant?
Yes, there is a name for the analogous case in Tait-Bryan angles. It's called "Steady Turn," also known as "Constant Turn" or "Banked Turn." In this case, the yaw rate is constant, the pitch rate is zero, and the roll rate is constant. The term "banked turn" refers to the fact that the vehicle or object is banked or tilted to one side, like an airplane during a turn. This term is commonly used in aviation and aerospace engineering.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
