Euler's Formula - Moving Particle Argument (Needham)
In summary, Needham's argument in support of Euler's formula is based on the claim that the particle will travel around a unit circle. This is the geometric statement of Euler's formula. However, Needham does not provide a rigorous proof of this claim.
Math Amateur
MHB
3,998
48
I am reading Tristan Needham's book "Visual Complex Analysis" and am currently focussed on Chapter 1, Section II Euler's Formula ... in particular I am trying to follow Needham's heuristic argument in support of, or justifying, Euler's formula - Needham calls it 'the moving particle argument' ... ...
In Chapter 1, Section II (2), Needham considers a particle moving along a curve:
##Z(t) = e^{it}##
So he finds that:
## \frac{dZ}{dt} = ie^{it} = iZ ##
Needham then argues that each new velocity, instant by instant, will be at right angles to its new position vector ( ? ... presumably because the function ##iZ## causes a rotation of 90 degrees - is that right? ... ) ...
He then asserts that "it is clear" that the particle will travel around a unit circle ... ... BUT ... ... why exactly is this the case? ... ... indeed, how do we rigorously prove that this is the case? ... ...
The relevant part of Needham's text is as follows:
Now ... just a further question based on a claim in the last paragraph above ... ...
Needham writes:
" ... ... Thus after time ##t = \theta## the particle will have traveled a distance ##\theta## round the unit circle, and so the angle of ##Z( \theta ) = e^{i \theta }## will be ##\theta##. This is the geometric statement of Euler's formula ... ... "My question is ... ... in what way ... that is how/why is this the geometric statement of Euler's formula ... ...
Help will be appreciated ...
Peter
Math Amateur said:
1) that the particle will travel around a unit circle ... ... BUT ... ... why exactly is this the case? ... ... 2) indeed, how do we rigorously prove that this is the case? ... ...
1) If you believe the 'at right angles' you have no tangential acceleration, so constant ##|\vec v|##. Since ##\vec v =i \vec Z##, it must be that ##|\vec Z| ## is also a constant. Circular motion. ##|\vec Z(0)| = 1##, so unit circle.
2) $${d\over dt}\vec Z^2 = 2\vec Z\cdot \vec v$$ right angles ##\Rightarrow## inner product is zero ##\Rightarrow\ \ \vec Z^2 ## is constant
If you're looking for rigor, then Needham's book is not what you're looking for. Don't get me wrong, it's an excellent work. But it's far from rigorous and not always easy to supply the rigor yourself.
Thanks BvU ... most helpful ...
But ... I am still puzzled regarding how Needham's argument supports/proves Euler's formula ...
Thanks again!
Peter
Thanks for a VERY helpful remark, Micromass ...
I must, in the light of what you have said, reevaluate my study of Needham's book ...
Peter
I agree with ##\mu m## but sometimes it's good not to worry about the foundations too much to become familiar with a large structure. You can always return to the basement in a later stage ...
Likes Math Amateur
So you have ##|\vec Z|## constant, 1 and ##\vec v## ... -- hey, I'm repeating Needham. $$|\vec Z|= 1 \quad \& \quad \angle \vec Z (= \arg {\bf Z}) = \theta \quad \Rightarrow \vec Z = \cos\theta\; \hat\imath + \sin \theta\; \hat\jmath \Rightarrow {\bf Z} = \cos \theta + {\bf i} \sin \theta $$
Likes Math Amateur
Hi BvU ... Thanks for both your new posts ...
VERY thoughtful point ... getting an idea of the big picture and a basic understanding of how things work in general is so important...
You have caused me to think yet again ...
Peter
I think it is still worth doing Needham. Needham contains so much information and cool background that you won't find in any other book in complex analysis. Sure, the book is not rigorous at all. And I think many of the arguments in Needham can't even be made rigorous. But Needham is also an amazing read and gives you so much intuition. It's really worth it.
Likes FactChecker
##d/dθ(cos(θ) + isin(θ)) = -sin(θ) + icos(θ)## and this equals ##i(cos(θ) + isin(θ))## so it differs from ##e^{iθ}## by a constant. But they are both equal to ##1## for ##θ=0## so they are equal for all ##θ##. But ##cos(θ) + isin(θ)## describes uniform circular motion so geometrically Euler's formula says the ##e^{iθ}## describes uniform circular motion as well.
Likes PeroK
Equality (10) follows directly from the Taylor expansions of the left and right sides. So why are all these wimp explanations needed?
wrobel said:
Equality (10) follows directly from the Taylor expansions of the left and right sides. So why are the all these wimp explanations needed?
Because it gives a lot of neat intuition about the Euler formula. If you think intuition is not necessary, then Needham is not the book for you.
Perhaps it would be instructive(though very wimp :nb)) to work out the solution to the differential equation ##dy/dθ = iy##
##y## is complex so ##y = u + iv## where ##u## and ##v## are real valued functions of ##θ##
##dy/y = idθ## and ##dy/y## = ##(du + idv)/u + iv = ((udu + vdv) + i(udv - vdu))/(u^2+v^2)##
The solution of ##∫dy/y = i∫dθ## is purely imaginary so udu + vdv = 0 or ##u^2 + v^2 = C## for some constant ##C##.
For ##θ=0## ## u=1## and ##v=0## so ##C =1## and ##u^2 + v^2## = 1 .
Since the real part of ##dy/y## is zero the equation becomes ##∫udv - vdu = ∫dθ##
Since ##v = \sqrt {1-u^2} ## , ##udv = -u^2/ \sqrt {1-u^2}du## and ##vdu = (1-u^2)/ \sqrt{1-u^2} du## so the left hand integral is ##∫-/ \sqrt{1-u^2}du## which integrates to the inverse cosine.
Given that ##u= cos(θ)## the differential equation gives ## v= sin(θ)##
Likes BvU and Math Amateur
##Z(t) = e^{it}##
So he finds that:
Yes.
##iZ## is therefore perpendicular to ##Z##
One way to think of it is that if the velocity vector has no component pointing away or towards the origin then the distance of the curve to the origin can not change. If a vector is perpendicular to a radial line segment it has no radial component.
Likes Math Amateur
Thanks so much Lavinia ... appreciate your help ...
Peter
Related to Euler's Formula - Moving Particle Argument (Needham)
1. What is Euler's Formula?
Euler's Formula, also known as the Moving Particle Argument, is a mathematical formula that relates the exponential function to trigonometric functions. It states that for any real number, x, the following equation holds: e^(ix) = cos(x) + i*sin(x), where e is the base of the natural logarithm, i is the imaginary unit, and cos(x) and sin(x) are the cosine and sine functions, respectively.
2. Who was Leonhard Euler?
Leonhard Euler was an 18th-century Swiss mathematician and physicist who is widely considered one of the greatest mathematicians in history. He made significant contributions to various fields of mathematics, including calculus, number theory, and graph theory. Euler's Formula is named after him as he was the first to publish it in its modern form.
3. How is Euler's Formula derived?
Euler's Formula can be derived using the Taylor series expansion of the exponential function and the fact that the derivatives of the sine and cosine functions repeat every four terms. This allows us to express the complex exponential function, e^(ix), as a sum of its real and imaginary parts, which are equal to the cosine and sine functions, respectively.
4. What are the applications of Euler's Formula?
Euler's Formula has various applications in mathematics, physics, and engineering. It is used to simplify complex trigonometric expressions, compute integrals and derivatives involving trigonometric functions, and solve differential equations. It is also used in signal processing, electrical engineering, and quantum mechanics.
5. Is Euler's Formula related to the famous identity, e^(i*pi) = -1?
Yes, Euler's Formula is closely related to the identity, e^(i*pi) = -1. This identity can be seen as a special case of Euler's Formula, where x = pi. Plugging in this value gives us e^(i*pi) = cos(pi) + i*sin(pi) = -1 + 0*i = -1, which is the famous identity discovered by Euler himself.
