Euler's Thirty-six officers problem?
  • Thread starter Thread starter tora
The Thirty-six Officers Problem is a combinatorial design challenge that involves arranging officers of different ranks and regiments in a way that no rank or regiment appears more than once in any row or column. The original problem, proposed by Euler in 1782, is considered unsolvable under its strict conditions. However, the discussion reveals that the poster found two arrangements that seem to satisfy some criteria, prompting questions about the problem's requirements. A key point raised is the necessity of incorporating both ranks and regiments into the arrangement, which complicates the solution. Understanding the full constraints of the problem is essential for determining its solvability.
tora
I randomly came across this problem:
http://en.wikipedia.org/wiki/Thirty-six_officers_problem
however, the problem is described as NOT being solvable.
But just goofing around, I found TWO solutions:
1 6 5 4 3 2
2 1 6 5 4 3
3 2 1 6 5 4
4 3 2 1 6 5
5 4 3 2 1 6
6 5 4 3 2 1
1 2 3 4 5 6
2 3 5 6 1 4
3 1 6 5 4 2
5 6 4 3 2 1
6 4 1 2 3 5
4 5 2 1 6 3
Clearly, I am not smarter that every mathmetician since 1782. I must not actually unstand what the problem is.
Could someone explain it to me?
Afraid you've only done half the job.
Let's assume the numbers 1-6 are the ranks of the officers, you still have to put on the regimental uniforms. E.g. 1a, 1b, ... 1f, 2a, 2b, ... 6f. Then you need to make sure you also don't have an a, b, c etc. twice in any row or column.
E.g. if it were three ranks and regiments:
1b 2c 3a
2a 3b 1c
3c 1a 2b
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 34 ·
  • · Replies 33 ·
