EV vs V, Cutoff Potential Question
In summary: The correct calculation for the maximum kinetic energy of the emitted electrons is 0.76*10^-19 Joules. The cutoff potential required to stop the photoelectrons is 0.47 Volts. The electron volt is a unit of energy equal to 1.6 × 10-19 joules. The formula for calculating cutoff potential is Vo = KE / e.
uberclay
Light with a wavelength of 630 nm is directed at a metallic surface that has a work function of 1.5 eV. Find
a) the maximum kinetic energy of the emitted electrons
b) the cutoff potential required to stop the photoelectrons
Ek = [(h * c) / λ] - W
Ek = e V0, where V0 is the cutoff potential and e = 1.60*10^-19
Ek = [(h * c) / λ] - W = [(1.989*10^-25 * 3.00*10^8) / 6.30*10^-7] - W
Ek = 3.16*10^-19 - (1.5 * 1.60*10^-19) = 3.16*10^-19 - 2.4*10^-19
Ek = 0.76*10^-19 Joules
a) maximum kinetic energy = 0.76*10^-19 Joules
Ek = e V0 therefore V0 = Ek / e
V0 = = 0.76*10^-19 / 1.60*10^-19 = 0.47 V
b) cutoff potential = 0.47 Volts
(b) is where I think I am confused, are volts and electron volts the same? And should the value be negative (electrons have negative charge and are repulsed by negative charges)?
Thank you for your help.
So the e in the equation above is not for the conversion of joules to electron volts, but the elementary charge? And are my calculations correct?
a)
OK I ran through your calculation quickly and I'm getting a different answer to you.
What are you using as Plancks constant, h? You seem to be using 1.989E-25 ?
b)
Imagine the electron leaving the metals surface at a point X and being detected at a point Y.
A potential is applied between point X and Y to deccelerate the electrons. Now since the electron is slowing down work is being done on the electron.
The formula for work done on an electron is, W=e * V , where W is work done, e is the elementary charge and V is the potential the electron is travelling.
The cutoff potential is the voltage between X and Y that just stops any electrons reaching Y. So at that point, W = KE , where KE is the kinetic energy of your electrons.
So re arranging you get Vo = KE / e .
Sorry - I copied it over wrong. The 1.989E-25 is (h * c), where h = 6.63E-34, so it should read
Ek = [(h * c) / λ] - W = [1.989*10^-25 / 6.30*10^-7] - W
Thank you for your assistance.
Related to EV vs V, Cutoff Potential Question
1. What is the difference between EV and V?
EV (electron volts) and V (volts) are both units of energy, but they measure energy in different ways. EV is a unit of energy that is often used to describe the energy of particles at the atomic or subatomic level, while V is a unit of energy that is commonly used to measure the potential difference between two points in an electric field.
2. How do EV and V relate to each other in terms of energy?
One electron volt (1 eV) is equal to the amount of energy gained by an electron when it is accelerated through a potential difference of one volt. This means that 1 eV is equivalent to 1 volt times the electric charge of an electron (1.6 x 10^-19 coulombs).
3. What is the significance of the cutoff potential in electron spectroscopy?
The cutoff potential, also known as the work function, is the minimum amount of energy required for an electron to escape from the surface of a material. In electron spectroscopy, the cutoff potential is used to determine the energy of the electrons that are emitted from a material, which can provide information about the electronic structure of the material.
4. How does the cutoff potential affect the electron emission from a material?
If the energy of an incoming electron is lower than the cutoff potential, it will not have enough energy to escape from the surface of the material. However, if the energy of the incoming electron is higher than the cutoff potential, it will be able to overcome the potential barrier and be emitted from the material.
5. Can the cutoff potential be changed in electron spectroscopy experiments?
Yes, the cutoff potential can be changed by adjusting the potential difference between the electron source and the material being studied. This allows for the study of different energy levels and can provide more detailed information about the electronic structure of a material.
