Evaluate (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c)
  • MHB
  • Thread starter anemone
In summary, the problem involves finding the value of $\dfrac{1-a}{1+a}+\dfrac{1-b}{1+b}+\dfrac{1-c}{1+c}$, given that $a,\,b,\,c$ are the roots of the cubic equation $x^3-x-1=0$. Using the fact that the sum of the roots is $0$, the sum of the products of the roots taken two at a time is $-1$, and the product of the roots is $1$, we can simplify the expression to $\dfrac{3 - 3abc}{1 + abc}$. Since $abc=1$, this simplifies further to $\dfrac{1}{1
anemone
MHB
POTW Director
3,883
115
If $a,\,b,\,c$ are the roots of $x^3-x-1=0$, evaluate $\dfrac{1-a}{1+a}+\dfrac{1-b}{1+b}+\dfrac{1-c}{1+c}$.
Mathematics news on Phys.org
$\dfrac{1-a}{1+a}=1- \dfrac{2a}{1+a}=1-\dfrac{2}{1+\dfrac{1}{a}}$
so $\dfrac{1}{a},\,\dfrac{1}{b},\,\dfrac{1}{c}$ are the roots of $\dfrac{1}{x^3}-\dfrac{1}{x}-1=0$
or $x^3+x^2-1=0$
so $1+\dfrac{1}{a},\,1+\dfrac{1}{b},\,1+\dfrac{1}{c}$ are the roots of
$(x-1)^3+(x-1)^2-1=0$
or $x^3-3x^2+3x-1 +x^2-2x+1-1=0$
or $x^3-2x^2+x-1=0$
so $\dfrac{1}{1+\dfrac{1}{a}},\,\dfrac{1}{1+\dfrac{1}{b}},\,\dfrac{1}{1+\dfrac{1}{c}}$ are the roots of
$\dfrac{1}{x^3}-\dfrac{2}{x^2}+\dfrac{1}{x}-1=0$
or
$x^3-x^2+2x-1= 0$
so $\dfrac{1}{1+\dfrac{1}{a}}+\,\dfrac{1}{1+\dfrac{1}{b}}+\,\dfrac{1}{1+\dfrac{1}{c}}= 1$
or $\dfrac{a}{1+a}+\,\dfrac{b}{1+b}+\,\dfrac{c}{1+c}= 1$
or $\dfrac{2a}{1+a}+\,\dfrac{2b}{1+b}+\,\dfrac{2c}{1+c}= 2$
or $1- \dfrac{2a}{1+a}+1- \,\dfrac{2b}{1+b}+1-\,\dfrac{2c}{1+c}= 3-2$
or $\dfrac{1-a}{1+a}+\,\dfrac{1-b}{1+b}+\,\dfrac{1-c}{1+c}= 1$
Hello, anemone!
evaluate $\,Y \;=\;\dfrac{1-a}{1+a}+\dfrac{1-b}{1+b}+\dfrac{1-c}{1+c}$
[sp]
Since $a,\,b,\,c$ are roots of the cubic: $\;\begin{Bmatrix}a+b+c &=& 0 \\ ab + bc + ac &=& \text{-}1 \\ abc &=& 1 \end{Bmatrix}$Then: $\,Y \,=\,\dfrac{(1-a)(1+b)(1+c) + (1+a)(1-b)(1+c) + (1+a)(1+b)(1-c)}{(1+a)(1+b)(1+c)} $
The numerator simplifies to:
$\quad 3 + (a+b+c) - (ab + bc + ac) - 3abc$
$\qquad =\:3 + 0 - (\text{-}1) - 3(1) \;=\;1$
The denominator simplifies to:
$\quad 1 + (a+b+c) + (ab+bc+ac) + abc$
$\qquad =\:1+0+(\text{-}1)+1 \;=\;1$
Therefore: $\:Y \;=\;\dfrac{1}{1} \;=\;1$
[/sp]
soroban said:
Hello, anemone![sp]
[/sp]
neat and elegent
soroban said:
Hello, anemone![sp]
[/sp]
Well done, soroban! Very neatly done instead!(Yes) And thanks for participating!:)
or $x^3+x^2-1=0$
or $x^3-2x^2+x-1=0$
or
$x^3-x^2+2x-1= 0$
Hi kaliprasad, your solution is great as well, thanks for participating, kali!
Another method that is quite similar to kali's method:
$\begin{align*}\dfrac{1-a}{1+a}+\dfrac{1-b}{1+b}+\dfrac{1-c}{1+c}&=\dfrac{1+a-2a}{1+a}+\dfrac{1+b-2b}{1+b}+\dfrac{1+c-2c}{1+c}\\&=3-2\left(\dfrac{a}{1+a}+\dfrac{b}{1+b}+\dfrac{c}{1+c}\right)\\&=3-2\left(\dfrac{1+a-1}{1+a}+\dfrac{1+b-1}{1+b}+\dfrac{1+c-1}{1+c}\right)\\&=3-6+2\left(\dfrac{1}{1+a}+\dfrac{1}{1+b}+\dfrac{1}{1+c}\right)\\&=2\left(\dfrac{1}{1+a}+\dfrac{1}{1+b}+\dfrac{1}{1+c}\right)-3\end{align*}$
We're told that $a,\,b,\,c$ are the roots of $f(x)=x^3-x-1$, hence, the function $f(x-1)=(x-1)^3-(x-1)-1=x^3-3x^2+2x-1$ has roots $a+1,\,b+1,\,c+1$ and hence the sum of the reciprocal roots of $a+1,\,b+1,\,c+1$ is 2.
$\therefore \dfrac{1-a}{1+a}+\dfrac{1-b}{1+b}+\dfrac{1-c}{1+c}=2\left(\dfrac{1}{1+a}+\dfrac{1}{1+b}+\dfrac{1}{1+c}\right)-3=2(2)-3=1$
FAQ: Evaluate (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c)
What is the formula for "Evaluate (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c)"?
The formula for this expression is (1-a)/(1+a) + (1-b)/(1+b) + (1-c)/(1+c).
How do I simplify the expression (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c)?
To simplify this expression, you can first find the common denominator, which is (1+a)(1+b)(1+c). Then, use the distributive property to expand each fraction and combine like terms. The simplified expression is (3+ab+ac+bc)/(1+a+b+c+ab+ac+bc).
Can the expression (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c) be written in a different form?
Yes, this expression can also be written as (1+a)(1+b)(1+c) - (a+b+c+ab+ac+bc)/(1+a+b+c+ab+ac+bc). This is known as the "difference of squares" form.
Is there a specific value for a, b, and c where the expression (1-a)/(1+a)+(1-b)/(1+b)+(1-c)/(1+c) is undefined?
Yes, when a = -1, b = -1, or c = -1, the expression will be undefined because it will result in a division by zero.
How can I use this expression to solve real-world problems?
This expression can be used in various mathematical and scientific calculations, such as in economics, physics, and engineering. It can also be used to find the average of a set of numbers by assigning a, b, and c to the values in the set. Additionally, this expression can be used to simplify complex fractions in algebraic equations.
