MHB Evaluate 19q + 99p: 2x^3-8x^2+9x+p=0
  • Thread starter Thread starter anemone
The discussion focuses on evaluating the expression 19q + 99p, where p and q are derived from two cubic equations sharing two common roots. Using Vieta's relations, it is established that the roots lead to p = -9 and q = 15. Substituting these values into the expression results in 19q + 99p = -606. Participants acknowledge the effectiveness of the solutions provided, with some noting the problem's lack of depth. The final consensus is that the calculations confirm the result of -606.
anemone
MHB
POTW Director
Two of the roots of the equation $$2x^3-8x^2+9x+p=0$$ are also roots of the equation $$2x^3+8x^2-7x+q=0$$. Evaluate $$19q+99p$$.
Mathematics news on Phys.org
Re: Evaluate 19q+99p
Use Vieta's relations. The sum of the roots of the first equation is $4$, and the sum of the roots of the second equation is $-4$. So if the roots of the first equation are $\alpha,\ \beta$ and $\gamma$, then the roots of the second equation are $\alpha,\ \beta$ and $\gamma-8$. Vieta's relations tell us that
$$\alpha\beta + \beta\gamma + \gamma\alpha = 9/2,\qquad \alpha\beta + (\alpha+\beta)(\gamma-8) = -7/2.$$ Therefore $-\frac72 = \frac92 - 8(\alpha+\beta)$, from which $\alpha+\beta = 1$. But $\alpha + \beta + \gamma = 4$, and so $\gamma=3$ (and $\gamma-8 = -5$).
Putting $x=3$ as a solution to the first equation, you find that $p=-9$; and putting $x=-5$ as a solution to the second equation, you find that $q=15$.
You can then find $19q + 99p = -606$ but that seems a bit pointless.
I thought the same but my way was a little longer. There must be a clever way at getting to the answer.
Hmm...now that I see how Opalg approached the problem, I have to admit that this problem serves little purpose and is a weak problem.
Hi Jester, I think what Opalg has given here is the smartest and shortest solution but having said this, I will also show my solution in this post.
Let a, b, and m be the roots of the equation $$2x^3-8x^2+9x+p=0$$ and a, b and k be the roots of the equation $$2x^3+8x^2-7x+q=0$$.
We see that the sum of the roots for both equations are:
$$a+b+m=4$$
$$a+b+k=-4$$
Subtracting the second equation from the first equation, we obtain:
$$m-k=8$$
and the product of the roots for both equations are:
$$abm=-\frac{p}{2}$$, $$abk=-\frac{q}{2}$$
Dividing these two equations, we obtain:
$$\frac{m}{k}=\frac{p}{q}$$
By Newton Identities, we have:
$$(a^2+b^2+m^2)(2)+(-8)(4)+2(9)=0\implies a^2+b^2+m^2=7$$
$$(a^2+b^2+k^2)(2)+(8)(-4)+2(-7)=0\implies a^2+b^2+k^2=23$$
Subtracting these two equations yields:
$$k^2-m^2=16$$
$$(k+m)(k-m)=16$$
$$(k+m)(-8)=16$$
$$m+k=-2$$
Solving the equations $m+k=-2$ and $m-k=8$ for both $m$ and $k$, we get $m=3$ and $k=-5$.
When $m=3$, $$a+b+3=4\implies a+b=1$$
Substituting $m=3,\,k=-5,\,a+b=1$ back into the equations $$a^2+b^2+m^2=7$$, $$abm=-\frac{p}{2}$$ and $$abk=-\frac{q}{2}$$, we see that:
$$(a+b)^2-2ab+(3)^2=7$$
$$(1)^2-2ab+(3)^2=7$$
$$ab=\frac{3}{2}$$
Hence, $$\frac{3}{2}(3)=-\frac{p}{2}\implies p=-9$$ and $$\frac{3}{2}(-5)=-\frac{q}{2}\implies q=15$$.
And this gives $$19q+99p=19(15)+99(-9)=-606$$
I must applaud you for posting your solution...I know from experience that it can be daunting to post a solution when others have shown a shorter or more clever route. (Sun)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
