Evaluate ab+bc+ca Given Real Numbers
  • MHB
  • Thread starter anemone
In summary, the purpose of evaluating ab+bc+ca given real numbers is to determine its numerical value, which can be useful in various mathematical and scientific applications. To evaluate this expression, you can substitute the given real numbers for the variables and perform necessary operations. Any real numbers can be used for a, b, and c, and the order of the numbers does not affect the final result due to the commutative properties of multiplication and addition. In scientific research, evaluating this expression can help determine relationships between variables and provide insight into system behavior.
anemone
MHB
POTW Director
3,883
115
Given real numbers $a,\,b,\,c$ such that
$a^2+ab+b^2=2$, $b^2+bc+c^2=3$, $c^2+ca+a^2=5$
Evaluate $ab+bc+ca$.
Mathematics news on Phys.org
Rewrite the given equations as follows:
$$\frac{a^2+b^2-(\sqrt{2})^2}{2ab}=\frac{-1}{2}$$
$$\frac{b^2+c^2-(\sqrt{3})^2}{2bc}=\frac{-1}{2}$$
$$\frac{a^2+c^2-(\sqrt{5})^2}{2ca}=\frac{-1}{2}$$
The above three equations geometrically represent the following triangle:
(As it can be clearly seen, the bigger triangle is a right-angled triangle.)
The areas of three smaller triangles add to give the area of bigger triangle. Hence,
$$\frac{1}{2}ab\sin(120^{\circ})+\frac{1}{2}bc\sin(120^{\circ})+\frac{1}{2}ca\sin(120^{\circ})=\frac{1}{2}\sqrt{2}\sqrt{3}$$
$$\Rightarrow ab+bc+ca=\frac{\sqrt{6}}{\sin(120^{\circ})}=\boxed{2\sqrt{2}}$$
$\blacksquare$
Thanks for participating, Pranav! Your answer is correct, well done!:)
FAQ: Evaluate ab+bc+ca Given Real Numbers
What is the purpose of evaluating ab+bc+ca given real numbers?
The purpose of evaluating this expression is to determine its numerical value. This can be useful in various mathematical and scientific applications, such as solving equations or analyzing data.
How do I evaluate ab+bc+ca given real numbers?
To evaluate this expression, you first need to substitute the given real numbers for the variables a, b, and c. Then, you can perform the necessary operations (multiplication and addition) to obtain the final numerical value.
Can I use any real numbers for a, b, and c?
Yes, you can use any real numbers for a, b, and c. Real numbers include all rational and irrational numbers, such as fractions, decimals, and square roots.
Is the order of the numbers important when evaluating ab+bc+ca?
No, the order of the numbers does not affect the final result when evaluating this expression. This is because multiplication and addition are commutative operations, meaning the order of the operands does not change the outcome.
What is the significance of evaluating ab+bc+ca given real numbers in scientific research?
In scientific research, evaluating this expression can help determine the relationships between variables in a system. It can also provide insight into the behavior of the system and aid in making predictions or drawing conclusions.
