How to Evaluate $\dfrac{a^5+b^5+c^5-1}{abc}$ Given $ab+bc+ca=0$ and $abc\ne 0$?
  • MHB
  • Thread starter anemone
  • Tags
    Expression
In summary, given $a,\,b,\,c \in \mathbb{R}$ such that $ab+bc+ca=0$ and $abc\ne 0$, the expression $\dfrac{a^5+b^5+c^5-1}{abc}$ simplifies to $2$.
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,,c \in \mathbb R$ such that $ab+bc+ca=0$ and $abc\ne 0$. Evaluate $\dfrac{a^5+b^5+c^5-1}{abc}$.
Mathematics news on Phys.org
Hello,
Interesting problem! First, let's rewrite the given conditions as $ab = -bc - ca$ and $abc \neq 0$. We can then substitute this into the expression we are trying to evaluate to get:
$\dfrac{a^5+b^5+c^5-1}{abc} = \dfrac{a^5 + (-bc)^5 + (-ca)^5 - 1}{abc}$
Using the binomial theorem, we can expand the terms with exponents to get:
$\dfrac{a^5 + b^5 + c^5 - 1}{abc} = \dfrac{a^5 - b^5 - c^5 + 1}{abc}$
Next, we can factor the numerator as a difference of squares:
$\dfrac{a^5 - b^5 - c^5 + 1}{abc} = \dfrac{(a^2-b^2)(a^3+b^3) - c^5 + 1}{abc}$
Using the identities $a^2-b^2 = (a-b)(a+b)$ and $a^3+b^3 = (a+b)(a^2-ab+b^2)$, we can further simplify the numerator to get:
$\dfrac{(a-b)(a+b)(a^2-ab+b^2)(a^2+b^2) - c^5 + 1}{abc}$
Since $ab = -bc - ca$, we can rewrite $a^2 + b^2$ as $(a+b)^2 - 2ab$. Substituting this in, we get:
$\dfrac{(a-b)(a+b)(a^2-ab+b^2)((a+b)^2 - 2ab) - c^5 + 1}{abc}$
Using the fact that $ab = -bc - ca$ again, we can simplify the expression further to get:
$\dfrac{(a-b)(a+b)(a^2-ab+b^2)(a^2 + b^2 + 2bc + 2ca) - c^5 + 1}{abc}$
Finally, we can substitute $ab = -bc - ca$ and $abc \neq 0$ into the expression to get our final answer of:
Related to How to Evaluate $\dfrac{a^5+b^5+c^5-1}{abc}$ Given $ab+bc+ca=0$ and $abc\ne 0$?
What is an algebraic expression?
An algebraic expression is a mathematical phrase that contains variables, numbers, and mathematical operations such as addition, subtraction, multiplication, and division. It does not contain an equal sign and cannot be solved.
How do you evaluate an algebraic expression?
To evaluate an algebraic expression, you need to substitute the given values for the variables and then use the order of operations (PEMDAS) to simplify the expression. Start by solving any operations within parentheses, then exponents, then multiplication and division from left to right, and finally addition and subtraction from left to right.
What is the difference between an expression and an equation?
An expression is a mathematical phrase that contains variables, numbers, and mathematical operations, whereas an equation is a statement that shows the equality of two expressions. An equation has an equal sign and can be solved to find the value of the variable.
Can an algebraic expression have more than one variable?
Yes, an algebraic expression can have more than one variable. In fact, it can have any number of variables as long as it follows the rules of algebra and can be simplified.
What are some common mistakes when evaluating algebraic expressions?
Some common mistakes when evaluating algebraic expressions include forgetting to use the order of operations, making errors while substituting values for variables, and incorrectly simplifying the expression. It is also important to pay attention to signs, such as negative signs, when combining like terms.
  • General Math
  • General Math
  • General Math
  • General Math
