Evaluate f(91π/2002) + f(92π/2002) + .... + (910π/2002)
  • MHB
  • Thread starter anemone
In summary, the sum of f(x) for values between $\displaystyle \frac{91\pi}{2002}$ and $\displaystyle \frac{910\pi}{2002}$ is equal to 410.
anemone
MHB
POTW Director
3,883
115
If \(\displaystyle f(x)=\frac{1}{1+\tan^3 x}\), evaluate \(\displaystyle f\left(\frac{91\pi}{2002} \right)+f\left(\frac{92\pi}{2002} \right)+\cdots+f\left(\frac{910\pi}{2002} \right)\).
Mathematics news on Phys.org
Re: Evaluate f(91π/2002)+f(92π/2002)+...+(910π/2002)
f(x) = cos ^3 x/( sin ^3 x + cos^3 x)
f(π/2 -x) = sin ^3 x / ( sin ^3 x + cos^3 x)
So f(x) + f(π/2-x) = 1
So f(91π/2002) + f(910π/2002) = 1 as 91π/2002 + 910π/2002 = π/2
Similarly upto
f(500π/2002) + f(501π/2002) =1
we have 410 pairs and sum = 410
Using the fact $\displaystyle f(x)+f\left(\frac{\pi}{2}-x\right) = \frac{1}{1+\tan^3 (x)}+\frac{1}{1+\cot^3(x)} = \frac{1+\tan^3 (x)}{1+\tan^3 (x)} = 1$
So we get $\displaystyle f(x)+f\left(\frac{\pi}{2}-x\right) = 1$
Now put $\displaystyle x = \frac{91\pi}{2002}$ to $\displaystyle x = \frac{500\pi}{2002}$
$\displaystyle \sum_{r=91}^{910} f\left(\frac{r\cdot\pi}{2002}\right) = 1+1+1+....+1)(410)$ -times
So $\displaystyle \sum_{r=91}^{910} f\left(\frac{r\cdot\pi}{2002}\right) = 410$
FAQ: Evaluate f(91π/2002) + f(92π/2002) + .... + (910π/2002)
What does "f" represent in the given equation?
In this equation, "f" represents a function that takes in a value and returns an output.
What is the value of "f" in this equation?
The value of "f" is not specified in the given equation. It could represent any function.
What does the expression (91π/2002) + (92π/2002) + ... + (910π/2002) represent?
This expression represents a sequence of values that are being input into the function "f". Each term in the sequence is slightly larger than the previous one, as the values are increasing by 1π/2002 each time.
Can the given equation be simplified?
It depends on the specific function "f" being used. Some functions may have a simplified form for this equation, while others may not.
How can this equation be evaluated?
To evaluate this equation, you would need to know the specific function "f" being used. You would then plug in each value from the sequence (91π/2002) + (92π/2002) + ... + (910π/2002) into the function and add all the resulting outputs together.
