Evaluate p^{2014}+q^{2014}+r^{2014}
  • MHB
  • Thread starter anemone
In summary, we have two polynomials $P(x)$ and $Q(x)$ with integer coefficients and $r\neq 0$. If $P(1)=0$ and the roots of $Q(x)$ are squares of the roots of $P(x)$, then the value of $p^{2014}+q^{2014}+r^{2014}$ is equal to $3$.
anemone
MHB
POTW Director
3,883
115
Let $P(x)=x^3+px^2+qx+r$ and $Q(x)=x^3+qx^2+rx+p$, where $p,\,q,\,r$ are integers with $r\ne 0$. Suppose $P(1)=0$ and the roots of $Q(x)$ are squares of the roots of $P(x)$. Find the value of $p^{2014}+q^{2014}+r^{2014}$.
Mathematics news on Phys.org
[sp]If the roots of $Q(x)$ are the squares of the roots of $P(x)$, then the roots of $Q(x^2)$ are the roots of $P(x)$ together with their negatives. The (monic) polynomial whose roots are the negatives of those of $P(x)$ is $P(-x)$. Therefore $Q(x^2) = P(x)P(-x)$. Thus $$x^6 + qx^4 + rx^2 + p = (x^3+px^2+qx+r) (x^3-px^2+qx-r) = x^6 + (2q-p^2)x^4 + (q^2-2pr)x^2 - r^2.$$ Compare coefficients of powers of $x$ to see that $$q=p^2, \qquad r = q^2-2pr, \qquad p=-r^2.$$ Hence $p=-r^2$, $q = r^4$ and $r^8+2r^3 - r = 0.$ But $r\ne0$, so $r^7 + 2r^2 - 1 = 0.$ The only integer solution of that is $r=-1$, so that $p=-r^2 = -1$ and $q = p^2 = 1.$ Finally, $p^{2014}+q^{2014}+r^{2014} = 1+1+1 = 3.$
[Note: It follows that $P(1) = 1+p+q+r = 1 - 1 + 1 - 1 = 0$. So the condition $P(1) = 0$ is automatically satisfied, and it seems that this condition was not needed in the statement of the problem.][/sp]
Well done Opalg! Your approach made it very obvious that we don't need the condition where $P(1)=0$ to solve for the problem, bravo! But, I think if we solved it using another route, then that condition is kind of needed.:eek:
Note that $P(1)=Q(1)=0$, so 1 is a root of both $P(x)$ and $Q(x)$. Let $m$ and $n$ be the other two roots of $P(x)$, so $m^2$ and $n^2$ are the other two roots of $Q(x)$.
We then get $mn=-r$ and $m^2n^2=-p$ so $p=-r^2$. Also, $(-p)^2=(m+n+1)^2=m^2+n^2+1+2(mn+m+n)=-q+2q=q$.
Therefore $q=r^4$. Since $P(1)=0$, we therefore get $1+r-r^2+r^4=0$. Factorizing, we get $(r+1)(r^3-r^2+1)=0$. Note that $r^3-r^2+1=0$ has no integer root and hence $r=-1$, $q=1$, $p=1$ and $\therefore p^{2014}+q^{2014}+r^{2014}=3$
FAQ: Evaluate p^{2014}+q^{2014}+r^{2014}
What does the expression p^{2014}+q^{2014}+r^{2014} mean?
The expression p^{2014}+q^{2014}+r^{2014} represents the sum of the 2014th powers of the three variables p, q, and r. This means that each variable is raised to the power of 2014 and then added together.
Why is it important to evaluate p^{2014}+q^{2014}+r^{2014}?
Evaluating the expression p^{2014}+q^{2014}+r^{2014} can provide important information about the values of the variables p, q, and r. It can also be used to solve equations and make predictions in various scientific and mathematical contexts.
How do you evaluate p^{2014}+q^{2014}+r^{2014}?
To evaluate p^{2014}+q^{2014}+r^{2014}, you need to substitute the values of p, q, and r into the expression, raise each value to the power of 2014, and then add them together. This will give you the final numerical value of the expression.
Can p^{2014}+q^{2014}+r^{2014} be simplified?
Yes, depending on the values of p, q, and r, the expression p^{2014}+q^{2014}+r^{2014} may be able to be simplified. For example, if one or more of the variables equals 0, the expression will simplify to the value of the remaining non-zero variable raised to the power of 2014.
Are there any real-world applications of p^{2014}+q^{2014}+r^{2014}?
Yes, there are many real-world applications of p^{2014}+q^{2014}+r^{2014}. For example, in physics, it can be used to calculate the total energy of a system. In economics, it can be used to model compound interest. In chemistry, it can be used to calculate the total atomic mass of a molecule. These are just a few of the many possible applications.
