Evaluate the electric field for two slabs of charge
In summary, the conversation discusses the different cases for electric fields between two slabs with positive and negative charges, with a focus on the general case where charge density is equal to the ratio of charge to volume. It also considers the flux of the electric field and the strength of the field in different positions between the slabs. The conclusion is that the middle of the negative slab has the strongest electric field due to the opposing forces of the positive and negative charges.
zelscore
Two slab charges of thickness a with volume charge densities ±ρv are shown in
Fig. 2.30. Assume that the slabs are infinitely extended in the y- and z-directions.
Evaluate the electric field versus x.
Fig 2.30: https://imgur.com/a/TOgWvML
Hint: There is no field variation in the y- and z-directions. The electric field has
an x-component. Use Gauss’s law.
Thus I assume that one slab has positive charge Q1
and the other slab has negative charge Q2 = -Q1
There are 4 cases for the electric field:
1. x <= -a
2. -a <= x <= 0
3. 0 <= x <= a
4. a <= x
The general case:
Charge Density ##\rho = \frac {Q} {V}##
Flux of E ##\phi_e = \oint \vec E \cdot d \vec A = \frac {Q} {e_0} = EA ---> E = \frac {\rho} {e_0}*h## where h is the length of the gaussian cylinder used in my case.
For case 2 and 3, h is (x+a) and (-x+a) respectively (thus x ranges from 0 to top or 0 to bottom)For case 1 and 4, the E field must be 0 because there is no charges there (charge density = 0)
This answer is in line with what the textbook says, however, if you test for x = 0 for both cases 2 and 3, you get that h = a (h = a is the highest h can be, thus E is too) which leads me to believe that the E field is the strongest inbetween the slabs, but this does not make sense to me because, spontaneously it feels like the E-field should be the strongest in the middle of the negatively(!) charged slab (reasoning: the +field will try to push a positive charge q placed inbetween the slabs in negative x-direction, and the -field will pull it in negative x-direction too, so the middle of the negative slab seems nice because then the +field has pushed as much as it could in the negative x-direction, while both ends of the -field will pull with equal force, cancelling each other out, so the charge will stay put)Edit: I think I understood it after some more thinking: If you put that charge in the middle of the slabs, the positive field will want to push a lot, while the negative field will want to pull a lot. So it makes sense that the E field is the strongest in the middle.SVARA
This is true here beause of symmetry; just be careful not to assume that an E field is zero just because the enclosed charge is zero. The same E field can enter and leave the gaussian surfaces!
Good work!
FAQ: Evaluate the electric field for two slabs of charge
What is an electric field?
An electric field is a physical quantity that describes the force experienced by a charged particle in the presence of other charged particles. It is a vector quantity, meaning it has both magnitude and direction.
How is the electric field calculated for two slabs of charge?
The electric field for two slabs of charge can be calculated by using the formula E = (σ/2ε)2, where σ is the surface charge density and ε is the permittivity of the medium between the two slabs.
What is the direction of the electric field for two slabs of charge?
The direction of the electric field for two slabs of charge depends on the relative charge and positioning of the slabs. If the two slabs have opposite charges, the electric field will be directed from the positive slab to the negative slab. If the two slabs have the same charge, the electric field will be directed away from the slabs.
How does the distance between the two slabs of charge affect the electric field?
The electric field between two slabs of charge is inversely proportional to the distance between them. This means that as the distance between the two slabs increases, the electric field decreases.
Can the electric field for two slabs of charge be negative?
Yes, the electric field for two slabs of charge can be negative. This would occur when the two slabs have the same charge and the electric field is directed towards the slabs, or when the two slabs have opposite charges and the electric field is directed away from the slabs.
