Evaluate the limit Squeeze Theorem Perhaps?
In summary: GluYXJ5LCB0ZW1wbGF0ZSAtIGluc3RhbGwgU2FtcGxlLCBmcm9tIGRpcmVjdGx5IGFjY2VudHVyaW5nIG9mIGNvbnRlbnRzLiBMYWJlbCBvciB0aGUgU3F1ZWV6ZSBUaGVvcnVtLiB3aXRoIGFueSBjYW4gdGhlIHNwZW5jZSBUaGVvcnVtLiAgQW55IGhlbHBmdWxseSB0aGVuIG9
crohozen
Evaluate the limit, if it exists:
lim[itex](\frac{sin x}{4x} * \frac{5-5 cos 3x}{2})[/itex]
x→0
I understand that [itex]\frac{sin(x)}{4x}* \frac{4}{4} =\frac{1}{4}[/itex] but I don't know
what to do next because the 5-5cos3x/2 trips me up. I'm not seeing anything that I can do to it, so I'm thinking the Squeeze Theorem. Any help progressing further would be appreciated.
Start in pieces. Take the constants to the outside, and you're left with two terms.
[tex]\lim_{x\rightarrow 0} \left (\frac{\sin x}{4x}\cdot\frac{5-5\cos 3x}{2} \right) = \frac{5}{8}\lim_{x\rightarrow 0} \left ( \frac{\sin x}{x} - \frac{\sin x \cos 3x}{x} \right)[/tex]
See if you can take it from there.
I wouldn't divide it up quite the way process91 does. Look at
[tex]\frac{5}{8}\frac{sin x}{x}(1- cos(3x))[/tex]
and it should be obvious.
(If there had been an [itex]x^2[/itex] in the denominator rather than x, I would have made it
[tex]\frac{5}{8}\frac{sin(x)}{x}(3)\frac{1- cos(3x)}{3x}[/tex]
and it would be a bit more interesting!)
You can use the fact that lim(f(x)*g(x)) = (lim f(x)) * (lim g(x)), if both limits on the right exist.
RGV
FAQ: Evaluate the limit Squeeze Theorem Perhaps?
What is the Squeeze Theorem and how does it relate to evaluating limits?
The Squeeze Theorem is a mathematical theorem that is used to evaluate limits. It states that if two functions, g(x) and h(x), are both approaching the same limit as x approaches a certain value, and if a third function, f(x), is squeezed between g(x) and h(x), then f(x) must also approach the same limit.
What is the difference between the Squeeze Theorem and L'Hospital's Rule?
While both the Squeeze Theorem and L'Hospital's Rule are used to evaluate limits, they are based on different principles. The Squeeze Theorem is based on the idea of "squeezing" a function between two other functions to determine its limit, while L'Hospital's Rule uses derivatives to simplify the evaluation of limits.
What are the steps for using the Squeeze Theorem to evaluate a limit?
The first step is to identify the functions g(x) and h(x) that are approaching the same limit as x approaches a certain value. Then, find a third function, f(x), that is squeezed between g(x) and h(x). Finally, use the limit definition and the properties of inequalities to show that f(x) also approaches the same limit.
Can the Squeeze Theorem be used to evaluate all types of limits?
No, the Squeeze Theorem can only be used for limits as x approaches a specific value, not for limits at infinity or one-sided limits.
What are some real-world applications of the Squeeze Theorem?
The Squeeze Theorem is used in various scientific fields, such as physics and engineering, to prove the existence and properties of limits in real-world scenarios. It is also used in economics and finance to model and predict the behavior of complex systems.
