MHB Evaluate the product of sines: sin1sin2sin3…sin89
  • Thread starter Thread starter lfdahl
    Product
The product of sines, \( P = \sin 1^\circ \sin 2^\circ \sin 3^\circ \cdots \sin 89^\circ \), can be evaluated using the formula \( \sin\frac{\pi}{m}\sin\frac{2\pi}{m}\cdots\sin\frac{(m-1)\pi}{m} = \frac{m}{2^{m-1}} \). By setting \( m = 180 \), it follows that \( \sin 1^\circ \sin 2^\circ \cdots \sin 179^\circ = \frac{180}{2^{179}} \). Utilizing the property \( \sin \theta = \sin(180^\circ - \theta) \) and knowing \( \sin 90^\circ = 1 \), we derive that \( (\sin 1^\circ \sin 2^\circ \cdots \sin 89^\circ)^2 = \frac{180}{2^{179}} \). Taking the square root yields \( \sin 1^\circ \sin 2^\circ \cdots \sin 89^\circ = \frac{3}{2^{88}}\sqrt{\frac{5}{2}} \).
lfdahl
MHB
Evaluate without the use of a calculator the product:$P = \sin 1\sin 2\sin 3…\sin 89$
(all angles in degrees)
Mathematics news on Phys.org
Could you give a hint please? (Angel)
Hint:
Use the identity: $\sin (x)\sin (60+x)\sin (60-x) = \frac{1}{4}\sin 3x$ (Nod)
Using the identities
$$\sin x\sin(60-x)\sin(60+x)=\frac 14\sin 3x \tag 1$$
$$\sin x\sin(90-x)=\frac 12\sin 2x \tag 2$$
$$\sin 36 = \sqrt{\frac 58 - \frac{\sqrt 5}8} \tag 3$$
$$\sin 72 = \sqrt{\frac 58 + \frac{\sqrt 5}8} \tag 4$$
we get:
\overbrace{\sin 1\sin2 ...\sin 89}^{89\text{ factors}}
=\frac 1 {4^{29}} \overbrace{\sin 3\sin 6...\sin 87}^{29}\cdot \sin 30 \cdot\sin 60 \\
=\frac 1 {4^{29+9}} \overbrace{\sin 9\sin 18...\sin 81}^{9}\cdot \sin^2 30 \cdot\sin^2 60 \\
=\frac 1 {4^{38}} \frac 1{2^4}\overbrace{\sin 18\sin 36\sin 54\sin 72}^{4}\cdot \sin^2 30 \cdot\sin 45 \cdot \sin^2 60 \\
=\frac 1 {4^{38}} \frac 1{2^{4+2}}\overbrace{\sin 36\sin 72}^{2}\cdot \sin^2 30 \cdot\sin 45 \cdot \sin^2 60 \\
=\frac 1{2^{82}}\cdot\sqrt{\frac 58 - \frac{\sqrt 5}8}\sqrt{\frac 58 + \frac{\sqrt 5}8}\cdot \frac 14 \cdot\sqrt{\frac 12} \cdot \frac 34 \\
=\frac 3{2^{86}}\cdot \sqrt{\frac{5}{2^4}}\cdot\sqrt{\frac 12}\\
=\frac {3}{2^{88}}\sqrt{\frac 52}
[sp]Another way to do this is to use the formula $\sin\frac{\pi}{m}\sin\frac{2\pi}{m}\sin\frac{3\pi}{m}\cdots\,\sin\frac{(m-1)\pi}{m}=\frac{m}{2^{m-1}}$ (posed as a challenge question by greg1313 in https://mathhelpboards.com/challenge-questions-puzzles-28/trigonometric-product-challenge-21867.html, and neatly solved by kaliprasad using complex roots of unity). If you put $m= 180$ in that formula then it becomes $$\sin 1^\circ \sin 2^\circ \sin 3^\circ \cdots \sin 179^\circ = \frac{180}{2^{179}}.$$ But $\sin \theta = \sin(180^\circ - \theta)$, and $\sin 90^\circ = 1$, so we can write that as $$\bigl(\sin 1^\circ \sin 2^\circ \sin 3^\circ \cdots \sin 89^\circ\bigr)^2= \frac{180}{2^{179}} = \frac{36\times 5}{2^{179}}.$$ Now take square roots to get $$\sin 1^\circ \sin 2^\circ \sin 3^\circ \cdots \sin 89^\circ = \frac{3}{2^{88}}\sqrt{\frac 52}.$$
[/sp]
we get:
Great job, I like Serena! Thankyou very much for a nice solution!(Happy)
- - - Updated - - -
[/sp]
Thankyou very much, Opalg for another exemplary solution!
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 70 ·
