MHB Evaluate |y²|+|z²| for Complex Numbers w/ |x+y+z|=21, |x-y|=2√3, |x|=3√3
  • Thread starter Thread starter anemone
The discussion revolves around solving the equation involving complex numbers where the conditions include |x+y+z|=21, |x-y|=2√3, and |x|=3√3. It is established that while no distinct real numbers satisfy the equation x²+y²+z²=xy+yz+xz, complex numbers do. The solution involves treating the problem geometrically, identifying that the complex numbers form an equilateral triangle in the complex plane. By applying the cosine rule and calculating distances, the final result is derived as |y|² + |z|² = 132. The discussion highlights the interplay between algebraic manipulation and geometric interpretation in complex number problems.
anemone
MHB
POTW Director
Hi MHB,
Problem:
While there do not exist pairwise distinct real numbers $x, y, z$ satisfying $x^2+y^2+z^2=xy+yz+xz$, there do exist complex numbers with that property. Let $x, y, z$ be complex numbers such that $x^2+y^2+z^2=xy+yz+xz$ and $|x+y+z|=21$.
Given that $|x-y|=2\sqrt{3}$, $|x|=3\sqrt{3}$, compute $|y^2|+|z^2|$.
Attempt:
I don't believe we have to assign all those variables $a, b, c, d, e, f$ so that we have $x=a+bi$, $y=c+di$ and $z=e+fi$ in order to begin attacking the problem, thus I don't know how to solve it.
Any help would be very much appreciated. Thanks.:)
Mathematics news on Phys.org
Peekaboo!
(Sorry, couldn't help myself when I saw that Opalg[/color] was responding. ;))
Another innocent-looking problem that took a long time to solve! But I see ILS is breathing down my neck so I had better respond fast.
Start in the most naive way possible, by writing $x^2+y^2+z^2=xy+yz+xz$ as a quadratic equation in $x$: $x^2 - (y+z)x + (y^2-yz+z^2) = 0$, with solution $$x = \tfrac12\bigl(y+z \pm\sqrt{-3(y-z)^2}\bigr) = \tfrac12\bigl(y+z \pm3(y-z)i\bigr) = \tfrac{1\pm\sqrt3i}2y + \tfrac{1\mp\sqrt3i}2z = \omega y + \overline{\omega}z,$$ where $\omega = \frac12(1\pm\sqrt 3i) = e^{\pm i\pi/3}$ and the bar denotes complex conjugate. By drawing the sixth roots of unity on the unit circle of the complex plane, you can see that $\omega^2 = \omega - 1 = -\overline{\omega}.$ From those relations, you can check that $y = \omega z + \overline{\omega}x$ and $z = \omega x + \overline{\omega}y.$ Also, $$x-y = (\omega y + \overline{\omega}z) - y = (\omega-1)y + \overline{\omega}z = \overline{\omega}(z - y).$$ It follows that $|x-y| = |z-y|$, and in the same way each of those is equal to $|x-z|$.
Thus $|y-z| = |z-x| = |x-y| = 2\sqrt3.$ So the points $x$, $y$, $z$ form an equilateral triangle in the complex plane, whose centroid is the point $c = \frac13(x+y+z)$ and thus $|c| = 7.$ The triangle has sides of length $2\sqrt3$, and the distance from each vertex to the centroid is $2$.
It's easier to describe what follows if I use capital letters to denote points in the complex plane corresponding to the above complex numbers. So $O$ will denote the origin, and we have an equilateral triangle $XYZ$ with centroid $C$, such that $OX = 3\sqrt3$, $OC = 7$, $XC=2$ and $XY = YZ = ZX = 2\sqrt3.$ (Draw a sketch to see what is going on.)
Now apply the cosine rule in the triangle $OXC$ to find the angle $\theta = \angle OXC$. It tells you that $$\cos\theta = \frac{OX^2 + XC^2 - OC^2}{2OX\cdot XC} = \frac{27 + 4 - 49}{12\sqrt3} = \frac{-18}{12\sqrt3} = -\frac{\sqrt3}2.$$ Therefore $\theta = 5\pi/6$. but $XC$ bisects the $(\pi/3)$-angle of the equilateral triangle. So the angles $OXY$ and $OXZ$ are $\frac56\pi \pm \frac{\pi}6$. In other words one of them, say $OXZ$, is $\pi$, and the other one, $OXY$, is $2\pi/3$.
It follows that $|z| = OZ = OX + XZ = 3\sqrt3 + 2\sqrt3 = 5\sqrt3.$ To find $|y|$, use the cosine rule again, in the triangle $OXY$. That gives $$|y|^2 = OY^2 = OX^2 + XY^2 -2OX\cdot XY \cos(2\pi/3) = 27 + 12 + 2\cdot\tfrac12\cdot 3\sqrt3\cdot 2\sqrt3 = 57.$$ Finally, $|y|^2 + |z|^2 = 57 + 75 = 132$.
Thank you very much, Opalg for providing a solution so clear.:)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
