Evaluating $162p-172q$ from 3 Common Roots
  • MHB
  • Thread starter anemone
In summary, the four roots of the first equation are $1$, $-2$, $-3$, and $-5$. The four roots of the second equation are $-6$, $-3$, $-1$, and $0$.
anemone
MHB
POTW Director
3,883
115
The following equations have 3 common roots:
$x^4-x^3-7x^2+x+p=0$
$x^4+5x^3+5x^2-5x+q=0$
Evaluate $162p-172q$.
Mathematics news on Phys.org
Re: Evaluate 162p-172q
Hello.
I have come to:
[tex]p=-q \rightarrow{}162p-172q=334p=-334q[/tex]
If it is that, the solution sought, I show the test.:eek:
Regards.
[sp]The sum of the roots of the first equation is $1$. The sum of the roots of the second equation is $-5$. The three roots common to both equations will also be roots of the difference between the equations, namely $6x^3 + 12x^2 - 6x + q-p.$ The sum of the roots of that equation is $-2$. Therefore the fourth root of the first equation is $1-(-2) = 3$, and the fourth root of the second equation is $-5-(-2) = -3$. Putting $x=3$ in the first equation and $x=-3$ in the second equation, we get
$3^4 - 3^3 - 7\cdot3 + 3 + p = 0$, from which $p=6$,
$3^4 - 5\cdot3^3 + 5\cdot3 + 5\cdot3 + q = 0$, from which $q=-6$.​
Therefore $162p - 172q = 6(162+172) = 2004$ (presumably this problem was set in that year).[/sp]
mente oscura said:
Hello.
I have come to:
Regards.
Hey mente oscura, yes, that is partially correct and you will gain full mark only if you have found the value of either $p$ or $q$ and substitute it into the equation.:)
Awesome! Your approach is a great one and thanks for participating again, Opalg!
My solution:
I first let $a, b, c$ be the three common roots of those two equations and $m$ be the fourth root of the equation $x^4-x^3-7x^2+x+p=0$ and $n$ be the fourth root of the equation $x^4+5x^3+5x^2-5x+q=0$.
Thus, we can rewrite the given two equations in a different form, that is:
$x^4-x^3-7x^2+x+p=(x-m)(x^3-(a+b+c)x^2+(ab+bc+ca)x-abc)$-(1)
$x^4+5x^3+5x^2-5x+q=(x-n)(x^3-(a+b+c)x^2+(ab+bc+ca)x-abc)$-(2)
Divide the equations and cross multiplying gives
$(x-m)(x^4+5x^3+5x^2-5x+q)=(x-n)(x^4-x^3-7x^2+x+p)$
By comparing the coefficient of $x^4$ and $x^3$ from both sides of the equation, we get:
$5-m=-1-n$ hence $m-n=6$
$5-5m=-7+n$ and therefore $n+5m=12$
Solving the equations $m-n=6$ and $n+5m=12$ we get
$m=3$ and $n=-3$
Since $m$ and $n$ are one of the roots of the equations, if we substitute them back and let each of them equals zero, we will get the value of $p$ and $q$ respectively:
$x^4-x^3-7x^2+x+p=(x-3)(x^3-(a+b+c)x^2+(ab+bc+ca)x-abc)$
$\therefore 3^4-3^3-7(2)^2+3+p=0$
$p=6$
$x^4+5x^3+5x^2-5x+q=(x+3)(x^3-(a+b+c)x^2+(ab+bc+ca)x-abc)$
$\therefore (-3)^4+5(-3)^3+5(-3)^2-5(-3)+q=0$$q=-6$
And therefore, $162p-172q=162(6)-172(-6)=2004$.
To evaluate $162p-172q$, we first need to find the common roots of the given equations. Since the equations have 3 common roots, we can set them equal to each other and solve for the common roots.
$x^4-x^3-7x^2+x+p = x^4+5x^3+5x^2-5x+q$
$-x^3-12x^2+6x+p-q = 0$
We can factor out an x from the left side to get:
$x(-x^2-12x+6)+p-q = 0$
Using the quadratic formula, we can solve for x:
$x = \frac{-(-12) \pm \sqrt{(-12)^2-4(1)(6)}}{2(1)} = \frac{12 \pm \sqrt{144-24}}{2} = \frac{12 \pm \sqrt{120}}{2} = \frac{12 \pm 2\sqrt{30}}{2} = 6 \pm \sqrt{30}$
Therefore, the common roots are $6+\sqrt{30}$, $6-\sqrt{30}$, and 0.
Now, we can plug in these values for x in either of the original equations to solve for p and q. For simplicity, let's use the first equation:
$(6+\sqrt{30})^4-(6+\sqrt{30})^3-7(6+\sqrt{30})^2+(6+\sqrt{30})+p = 0$
Simplifying this equation, we get:
$162+162\sqrt{30}+30\sqrt{30}+p = 0$
$p = -162-192\sqrt{30}$
Similarly, we can solve for q by plugging in the common roots in the second equation:
$(6+\sqrt{30})^4+5(6+\sqrt{30})^3+5(6+\sqrt{30})^2-5(6+\sqrt{30})+q = 0$
$q = -162-192\sqrt{30}$
Now, we can substitute these values for p and q in the expression $162p-172q$:
$162p-172q = 162(-162-192\sqrt{30})-
FAQ: Evaluating $162p-172q$ from 3 Common Roots
How do you evaluate $162p-172q$ from 3 common roots?
To evaluate $162p-172q$ from 3 common roots, you first need to identify the common roots among the terms. Then, you can factor out the common roots and simplify the expression.
What are common roots in an expression?
Common roots in an expression are factors that are shared among all the terms. They can be numbers, variables, or a combination of both.
Why is it important to factor out common roots when evaluating an expression?
Factoring out common roots helps to simplify the expression by reducing the number of terms and making it easier to solve. It also allows us to identify any patterns or relationships between the terms.
Can you evaluate an expression without factoring out common roots?
Yes, you can evaluate an expression without factoring out common roots, but it may make the process more complicated and time-consuming.
How do you know if you have factored out all the common roots in an expression?
You can check if you have factored out all the common roots by making sure that there are no more common factors that can be divided from all the terms. In other words, the expression should be simplified as much as possible.
