Evaluating a limit by integral test
In summary: The maximal error should be given by the first term, if you let the integral start at the point of the first term (here: at n=1).
MathewsMD
433
Evaluate ## ∑^∞_{n=1} \frac {2}{n(n+2)} ##
2. The attempt at a solution
I've solved this question simply enough by evaluating it as a telescoping series and found the answer as 3/2. Now, when applying the integral test, it only works when dealing with positive, decreasing functions, correct? I'm not exactly sure as to why you can only apply it under circumstances though (if someone could also explain this, that would help). My question is, why can't the integral test be applied in this situation? If I'm not mistaken, you get two different answers using the two methods (i.e. integral evaluation or telescoping) yet the sum posted fulfil the aforementioned criteria.
Working with the summation as a telescoping series, you found the sum of the series. The integral test doesn't give you the sum of the series, it gives you the integral of the function you're integrating, and this will be reasonably close to, but not the same as the summation.
I think that's what you're asking about, at least in part.
Where is the problem? Is ##\frac{2}{n(n+2)}## negative or not decreasing anywhere?
The integral gives a different value, but it confirmes that the series converges (that's all the test does).
Thank you! Is there a method to determine how accurate it is?
In general, no. The purpose of the integral test is to let you determine whether the series converges. In the summation, you're essentially adding the areas of a bunch of rectangles, each of width 1. The integral gives you the area under the curve y = f(x). The underlying geometric shapes for the two methods are different, which is why the two methods produce different values.
In general? Do you mind expanding please? :)
I didn't want to say a flat no, just in case there was some situation that I hadn't thought about. The important thing is that the integral test is just a test to determine whether a given series converges or not.
See attachment. The red dots mark the summands of the series. The red "curve" (step function) corresponds to an error-free integral, the grey "curve" to the worst case.
FAQ: Evaluating a limit by integral test
What is the purpose of evaluating a limit by integral test?
The purpose of evaluating a limit by integral test is to determine the convergence or divergence of a given infinite series. This can be done by comparing the series to a known integral, which allows us to use the properties of integrals to evaluate the limit.
How does the integral test work?
The integral test uses the properties of integrals to determine the convergence or divergence of a series. If the integral of the series converges, then the series also converges. Similarly, if the integral diverges, then the series also diverges.
When should I use the integral test to evaluate a limit?
The integral test should be used when the series in question is positive, continuous, and decreasing. It is also useful when the series is difficult to evaluate using other methods, such as the comparison test or the ratio test.
Can the integral test be used for all series?
No, the integral test can only be used for series that meet certain criteria, such as being positive, continuous, and decreasing. It is also important to check if the integral being compared to is convergent or divergent.
Are there any limitations to the integral test?
Yes, the integral test can only be used for series that meet certain criteria. Additionally, the integral test may not always provide a conclusive answer, as the integral being compared to may be difficult to evaluate. In these cases, other tests may need to be used in conjunction with the integral test.
