Evaluating a variable expression
In summary, the person is asking for clarification on the expression 5ab/12-2cb and is seeking recommendations for books to learn how to solve similar problems.
rodgerst414
a=4,b=3 and c=-2
5ab/12-2cb:confused:
Mathematics news on Phys.org
As posted, it is hard to tell if you mean:
$\displaystyle \frac{5ab}{12}-2cb$
or
$\displaystyle \frac{5ab}{12-2cb}$
Until you learn to use $\LaTeX$, I recommend you use bracketing symbols to make it clear exactly what the denominator is.
If the first choice above is what you intend, then you could type (5ab/12) - 2cb, and if the second choice is what you intend, then you could type (5ab)/(12 - 2cb).
Do you see how that removes the potential ambiguity?
or
it is the first one i just don't know how to put them in the calculator or write them on here.
Okay, you have technically written it correctly then, but there are so many students who would write what you did when they mean the second choice, that it is best to make sure.
Now, given what I told you in your first topic, what do you think you need to do here as the first step?
It is the first on you wrote how do you put into a calculator.
Sorry but this is my first time to do these problems i don't understand.I quit school at a younger age. i am 41 first time in college.This is this the class they put me in.Can you recommend some books for me to learn these kinds of problems.
We really don't need a calculator for this. What we want to do is use the values we are given for the variables and plug them into the expression. Can you write the expression with the numbers put into replace the variables?
rodgerst414 said:
...Can you recommend some books for me to learn these kinds of problems.
I think you have made a great start...you have come to a wonderful forum to get help, and I think once you get the hang of the procedure for these, you will understand what you need to do for other similar problems.
Books are good, but the feedback you get from helpers on a forum is much better.(Yes)
FAQ: Evaluating a variable expression
1. What is a variable expression?
A variable expression is a mathematical statement that contains variables, which are letters or symbols that represent unknown quantities. These expressions can include numbers, operations such as addition and multiplication, and variables.
2. How do you evaluate a variable expression?
To evaluate a variable expression, you substitute a given value for each variable and then use the order of operations to simplify the expression. This will result in a numerical value as the solution.
3. What is the order of operations for evaluating a variable expression?
The order of operations for evaluating a variable expression is PEMDAS, which stands for Parentheses, Exponents, Multiplication and Division (from left to right), and Addition and Subtraction (from left to right). This means that operations in parentheses are completed first, followed by any exponents, then multiplication and division, and finally addition and subtraction.
4. Can you give an example of evaluating a variable expression?
Sure! Let's evaluate the expression 3x + 5 when x = 2. First, we substitute the value of x into the expression, giving us 3(2) + 5. Then, we follow the order of operations and complete the multiplication first, resulting in 6 + 5. Finally, we add the two numbers together to get a final answer of 11. Therefore, when x = 2, the value of the expression 3x + 5 is 11.
5. Why is it important to evaluate variable expressions?
Evaluating variable expressions is important because it allows us to find the numerical value of a mathematical statement, which can then be used to solve real-world problems. It also helps us understand the relationship between variables and constants, and how they affect the outcome of a mathematical expression.
