MHB Evaluating an Infinite Sum of Binomial Coefficients
The discussion centers on evaluating the infinite sum of binomial coefficients, specifically $\sum_{n=2009}^{\infty} \frac{1}{\binom{n}{2009}}$. Participants confirm the correctness of a solution provided by Pranav and explore an alternative method involving a telescoping sum. A detailed mathematical derivation is shared, illustrating the relationship between binomial coefficients and the evaluation of the sum. The conversation emphasizes clarity in presenting solutions to avoid confusion among readers. Overall, the exchange highlights effective strategies for tackling complex binomial coefficient sums.
anemone
MHB
POTW Director
Evaluate $\displaystyle\lower0.5ex{\mathop{\large \sum}_{n=2009}^{\infty}} \dfrac{1}{n \choose 2009}$.
Mathematics news on Phys.org
anemone said:
Evaluate $\displaystyle \sum_{n=2009}^{\infty} \dfrac{1}{n \choose 2009}$.
Rewrite the sum as:
$$\sum_{n=2009}^{\infty} \frac{1}{n\choose 2009}=(2009)!\sum_{n=2009}^{\infty} \frac{(n-2009)!}{n!}=(2009)!\sum_{n=2009}^{\infty} \frac{1}{n(n-1)(n-2)(n-3)\cdots (n-2008)}$$
$$=(2009)!\sum_{n=0}^{\infty} \frac{1}{(n+1)(n+2)(n+3)\cdots (n+2009)}$$
To evaluate the above sum, we have to integrate the following 2009 times:
$$\frac{1}{1-x}=1+x+x^2+x^3+\cdots$$
I am unsure if the following is going to be correct. To integrate the above 2009 times, I used the technique of repeated integral as shown here: Repeated Integral -- from Wolfram MathWorld
So from above, I have to find the following:
$$\int_0^x \frac{(x-t)^{2008}}{(1-t)(2008)!}\,dt$$
at $x=1$, i.e
$$\int_0^1 \frac{(1-t)^{2007}}{(2008)!}=\frac{1}{(2008)!(2008)}$$
Hence,
$$(2009)!\sum_{n=0}^{\infty} \frac{1}{(n+1)(n+2)(n+3)\cdots (n+2009)}=(2009)!\frac{1}{(2008)!(2008)}=\boxed{ \dfrac {2009}{2008}}$$
I am not sure if what I have done is correct. :confused:
Pranav said:
Rewrite the sum as:
at $x=1$, i.e
Hence,
Well done, Pranav! I think what you have done is correct and that led to the correct answer as well.:cool:
The alternative way to evaluate this sum is to recognize that this sum is a telescoping sum and I will show you and others another good solution that I have seen somewhere online.
Observe that
$\begin{align*}\dfrac{k+1}{k} \left(\dfrac{1}{n-1 \choose k}-\dfrac{1}{n \choose k} \right)&=\dfrac{k+1}{k} \dfrac{{n \choose k}-{n-1 \choose k}}{{n \choose k}{n-1 \choose k}}\\&=\dfrac{k+1}{k} \dfrac{n-1 \choose k-1}{{n \choose k}{n-1 \choose k}}\\&=\dfrac{k+1}{k} \dfrac{(n-1)!k!k!(n-k-1)!(n-k)!}{n!(n-1)!(k-1)!(n-k)!}\\&=\dfrac{k+1}{k} \dfrac{k\cdot k! (n-k-1)!}{n!}\\&=\dfrac{1}{n-1 \choose k}\end{align*}$
Now, we apply this with $k=2008$ and sum across all $n$ from 2009 to $\infty$, and get
$\displaystyle\lower0.5ex{\mathop{\large \sum}_{n=2009}^{\infty}} \dfrac{1}{n \choose 2009}=\dfrac{2009}{2008} \lower0.5ex{\mathop{\large \sum}_{n=2009}^{\infty}} \left( \dfrac{1}{n-1 \choose 2008}-\dfrac{1}{n \choose 2008} \right)$
Notice that all terms from teh sum on the RHS cancel, except for the initial term of $\dfrac{1}{2008 \choose 2008}$, which is equal to 1, so we can conclude that
$\displaystyle\lower0.5ex{\mathop{\large \sum}_{n=2009}^{\infty}} \dfrac{1}{n \choose 2009}=\dfrac{2009}{2008}$
anemone said:
Observe that
That looks like a nice approach. Thanks for sharing! :)
Observe that
it should be:
$\begin{align*}\dfrac{k+1}{k} \left(\dfrac{1}{n-1 \choose k}-\dfrac{1}{n \choose k} \right)&=\dfrac{k+1}{k} \dfrac{{n \choose k}-{n-1 \choose k}}{{n \choose k}{n-1 \choose k}}\\&=\dfrac{k+1}{k} \dfrac{n-1 \choose k-1}{{n \choose k}{n-1 \choose k}}\\&=\dfrac{k+1}{k} \dfrac{(n-1)!k!k!(n-k-1)!(n-k)!}{n!(n-1)!(k-1)!(n-k)!}\\&=\dfrac{k+1}{k} \dfrac{k\cdot k! (n-k-1)!}{n!}\\&=\dfrac{1}{n \choose k+1}\end{align*}$
Yes, Albert, you're right. I will leave my original post as is so that we won't confuse the readers and I apologize to the community for not bringing enough attention when I composed the solution.(Tmi):o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
