MHB Evaluating an Integral: Laplace Transform Method
The discussion focuses on evaluating the integral ∫₀^∞ (cos(mx)/(a²+x²)) dx using the Laplace transform method instead of contour integration. The user breaks the problem into three parts, successfully completing the first two: showing that ∫₀^∞ e^(-t²x²) cos(mx) dx equals (√π/(2t)) e^(-m²/(4t²)), and that ∫₀^∞ e^(-(a²t² + m²/(4t²))) dt equals (√π/(2a)) e^(-am). The third part, which involves evaluating the original integral using the derived results, was initially challenging but is now considered trivial by the user. The thread illustrates a successful application of the Laplace transform in integral evaluation.
polygamma
The typical way to evaluate $ \displaystyle \int_{0}^{\infty} \frac{\cos mx}{a^{2}+x^{2}} \ dx$ is by contour integration.
In a recent thread I evaluated that integral using the Laplace transform.
http://mathhelpboards.com/analysis-50/advanced-integration-problem-9129.html#post42551My challenge question is to use the fact that $$ \frac{1}{a^{2}+x^{2}} = 2 \int_{0}^{\infty} t e^{-(a^{2}+x^{2}) t^{2}} \ dt $$ to show that
$$\int_{0}^{\infty} \frac{\cos mx}{a^{2}+x^{2}} \ dx = \frac{\pi}{2a} e^{-am} .$$
Mathematics news on Phys.org
I'm going to break the problem into three parts.1) Show that $ \displaystyle \int_{0}^{\infty} e^{-t^{2} x^{2}} \cos (mx) \ dx = \frac{\sqrt{\pi}}{2t} e^{-m^{2}/(4t^{2})}$.2) Show that $ \displaystyle \int_{0}^{\infty} e^{-[a^{2}t^{2} + m^{2}/(4t^{2})]} \ dt = \frac{\sqrt{\pi}}{2a} e^{-am}$.3) Evaluate $ \displaystyle \int_{0}^{\infty} \frac{\cos mx}{a^{2}+x^{2}} \ dx$ using the fact that $ \displaystyle \int_{0}^{\infty} \frac{\cos mx}{a^{2}+x^{2}} \ dx= 2 \int_{0}^{\infty} \int_{0}^{\infty} \cos(mx) t e^{-(a^{2}+x^{2}) t^{2}} \ dt \ dx $.
I have figured out the first two parts, still working on third. :)
Woops, third one is trivial now. :p
Problem 1.
Let
$$I(m)=\int_0^{\infty} e^{-t^2x^2}\cos(mx)\,\,dx$$
Differentiate wrt $m$,
$$I'(m)=-\int_0^{\infty} xe^{-t^2x^2}\sin(mx)\,\,dx$$
Integrate by parts and using the fact that $\int xe^{-t^2x^2}dx=-e^{-t^2x^2}/(2t^2)$, we get:
$$I'(m)=-\frac{mI(m)}{2t^2}$$
Solving the differential equation,
$$\ln I(m)=-\frac{m^2}{4t^2}+C$$
Since $I(0)=\frac{\sqrt{\pi}}{2t}$, we have $C=\ln(I(0))$, hence
$$\ln\left(\frac{I(m)}{I(0)}\right)=-\frac{m^2}{4t^2}$$
$$\Rightarrow I(m)=I(0)e^{-m^2/(4t^2)}=\frac{\sqrt{\pi}}{2t}e^{-m^2/(4t^2)}$$
Problem 2.
Let
$$I(m)=\int_0^{\infty} e^{-(a^2t^2+m^2/(4t^2))}dt=e^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\,dt$$
Differentiate wrt m to get
$$I'(m)=-ae^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\,dt+2e^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\left(a-\frac{m}{t^2}\right)\,dt$$
I rewrite $a-m/t^2$ as $2a-a-m/t^2$ and split the integral as follows:
$$I'(m)=-aI(m)+4ae^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\,dt-2e^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\left(a+\frac{m}{t^2}\right)\,dt$$
$$I'(m)=3aI-2e^{-am}\int_0^{\infty} e^{-(at-m/t)^2}\left(a+\frac{m}{t^2}\right)\,dt$$
Use the substitution $at-m/t=u$ in the integral.
$$\Rightarrow I'(m)=3aI(m)-2e^{-am}\int_{-\infty}^{\infty} e^{-u^2}\,du$$
Since
$$\int_{-\infty}^{\infty} e^{-u^2}\,du=\sqrt{\pi}$$
hence, we have the linear differential equation,
$$I'(m)-3aI(m)=-2e^{-am}\sqrt{\pi}$$
The integrating factor is $e^{-3am}$, hence,
$$I(m)\cdot e^{-3am}=\frac{\sqrt{\pi}e^{-4am}}{2a}+C$$
Since $I(0)=\frac{\sqrt{\pi}}{2a}$, we have $C=0$, hence
$$I(m)=\frac{\sqrt{\pi}}{2a}e^{-am}$$
Problem 3.
Rewrite the integral as
$$2\int_0^{\infty}te^{-a^2t^2}\int_0^{\infty} e^{-x^2t^2}\cos(mx)\,dx\,dt$$
From Problem 1, we can write:
$$2\int_0^{\infty}te^{-a^2t^2}\cdot\frac{\sqrt{\pi}}{2t}e^{-m^2/(4t^2)}\,dt=\sqrt{\pi}\int_0^{\infty}e^{-a^2t^2-m^2/(4t^2)}\,dt$$
From the result of problem 2, we have
$$\sqrt{\pi}\cdot \frac{\sqrt{\pi}}{2a}e^{-am}=\frac{\pi}{2a}e^{-am}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
