thatguythere
- 91
Evaluate sin^-1(cos70°)
sin^-1(cos70°)=θ
sinθ=cos70°
sinθ=1/2
sinθ=∏/3
thatguythere said:Homework Statement
Evaluate sin^-1(cos70°)Homework Equations
sin^-1(cos70°)=θ
sinθ=cos70°
sinθ=1/2
sinθ=∏/3
No, cos(90°-70°) = cos(20°) = sin(70°).thatguythere said:Ah a trig identity I see.
So cos(90°-70°)=sinθ
thatguythere said:cos(20°)=sinθ
0.94=sinθ
sin^-1(sinθ)=θ
sin^-1(0.94)=θ
0.94=θ
Because f-1(f(x)) = x, as long as x is in the domain of f. That's a basic property of a function and its inverse. It's also true that f(f-1(y)) = y, when y is in the domain of f-1. In short, the composition of a function and its inverse "cancels."thatguythere said:Alright. So if cos(90°-x)=sinx, which in my case is 70°, I still do not understand why Tanya then encourages me to use sin^-1(sinθ)=θ.
There's really no need for you to use θ, here, and I think that it is confusing you.thatguythere said:How is cos70° to be replaced by sinθ?
Not equivalent to - equal to.thatguythere said:By the trig identities, sin(90°-x)=cosx, it is sin20° which is equivalent to cos70°.
Make it simpler by getting rid of θ.thatguythere said:Would my equation then be accurately represented by sin^-1(sin20°)=θ and then simply by using cancellation identities reduced to 20°=θ?
Yes.thatguythere said:sin^-1(sin(20°))=20°=∏/9
Sure, you're welcome!thatguythere said:I apologize for being so confused, independent study is not being kind to me. Thank you very much, your help is immensely appreciated.
Mark44 said:That's what they pay me for!
Oh, wait - I'm an unpaid volunteer.
An inverse trigonometric function is a mathematical function that calculates the angle needed to produce a specific value in a trigonometric function. For example, if we know the sine of an angle, the inverse sine function can help us find the angle itself.
To evaluate an inverse trigonometric function, you first need to identify which function you are working with (such as sine, cosine, or tangent). Then, you can use a calculator or mathematical tables to find the inverse of the function. Alternatively, you can use algebraic manipulation to solve for the angle.
The domain of an inverse trigonometric function is the set of all possible input values (or angles) that can be plugged into the function. The range is the set of all possible output values (or angles) that the function can produce. In general, the domain of an inverse trigonometric function is restricted to specific intervals to ensure that the function is one-to-one (has a unique output for each input).
Yes, you can evaluate an inverse trigonometric function without a calculator by using algebraic techniques. For example, you can use the unit circle to find the reference angle and then apply trigonometric identities to solve for the angle.
Inverse trigonometric functions are commonly used in fields such as engineering, physics, and navigation. They can be used to calculate the angles and distances in geometric problems, as well as to model real-life situations involving periodic motion (such as the position of a pendulum or the motion of a satellite).
