Evaluating $\displaystyle \lim_{{x}\to{2}} f(x$): Does it Exist?
  • MHB
  • Thread starter Joel Jacon
In summary, when looking at a limit at $x=0$ on the left hand side we have negative numbers and on the right hand side we have positive numbers so when taking the left hand limit we consider negative values of $x$ and when taking the right hand limit we consider positive values of $x$.
Joel Jacon
Evaluate $\displaystyle \lim_{{x}\to{2}} f(x$) if it exist where $f(x)$ = x - |x| where x<2;4 where x = 2;3x - 5 where x>2?
LHL
$\displaystyle \lim_{{x}\to{2}} f(2x)$ = 4
RHL
$\displaystyle \lim_{{x}\to{2}} f(3x - 5)$ = 1
Therefore the limit x tend to 2 for the function does not exist.
Have I done correctly? If not tell me what mistake I made?
Mathematics news on Phys.org
If I'm understanding correctly this is a piecewise function, correct? Like this?
\(\displaystyle f(x)=\begin{cases}x-|x|, & x<2 \\[3pt] 4, & x=2 \\[3pt] 3x-5, & x>2 \\ \end{cases}\)
If so, then for the LHL we should look at what function applies when $x<2$. Which one is that? Once you pick that function what value do you get for 1.9, 1.99, 1.999, etc.?
Can you please tell me how to deal with the modulus. i know that x - |x| is the function to be used for LHL as x<2
I'm not familiar with the term modulus for these brackets, but that might another term for it. I'm interpreting it as absolute value, meaning its distance from 0. You are correct that our $f(x)$ is $x-|x|$. Try plugging in numbers as I suggested. Did you try that?
$(1.9-|1.9|)=(1.9-1.9)=0$
What about 1.99? 1.999?
EDIT: It seems modulus and absolute value are synonymous in this situation. Learn something new every day.
If modulus is the absolute value then can you explain me why we use $\lim_{{x}\to{0}} \frac{x}{|x|}$ as $\lim_{{x}\to{0}} \frac{x}{-x}$ for LHL
and $\lim_{{x}\to{0}} \frac{x}{x}$ for RHL for the question in which we have to show $\lim_{{x}\to{0}} \frac{x}{|x|}$ does not exist
Sure. When we are dealing with positive numbers, or $x>0$, then $|x|=x$. For example |5|=5. When we are dealing with negative numbers, or $x<0$ then |x|=-x. For example |-4|= -(-4)=4.
When are looking at a limit at $x=0$ on the left hand side we have negative numbers and on the right hand side we have positive numbers so when taking the left hand limit we consider negative values of $x$ and when taking the right hand limit we consider positive values of $x$.
Going back to the problem in this thread, what do you get for:
\(\displaystyle \lim_{{x}\to{2^-}}\hspace{1 mm} f(x)\)?
FAQ: Evaluating $\displaystyle \lim_{{x}\to{2}} f(x$): Does it Exist?
What does it mean for a limit to exist?
When we say that a limit exists, it means that the value that a function approaches as the input approaches a certain value, also known as the limit point, is well-defined and finite.
How do you determine if a limit exists?
To determine if a limit exists, we can use the definition of a limit or evaluate the left and right-hand limits at the limit point. If both the left and right-hand limits are equal, then the limit exists. However, if the left and right-hand limits are not equal, or if they are infinite, then the limit does not exist.
What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit evaluates the behavior of a function as the input approaches the limit point from either the left or the right. A two-sided limit, also known as a two-sided limit, evaluates the behavior of a function as the input approaches the limit point from both the left and the right.
Can a limit exist even if the function is not defined at the limit point?
Yes, a limit can exist even if the function is not defined at the limit point. This is because the limit only considers the behavior of the function as the input approaches the limit point, not the actual value of the function at the limit point itself.
Why is it important to evaluate limits?
Evaluating limits is important because it allows us to understand the behavior of a function near a certain point. This information is crucial in many mathematical and scientific applications, such as optimization problems, calculating derivatives, and determining the continuity of a function.
