Evaluating $f(\alpha)f(\alpha^2)...f(\alpha^{14})$
  • MHB
  • Thread starter DrunkenOldFool
In summary, we need to find the value of $f(\alpha)f(\alpha ^2) \cdots f(\alpha ^{14})$, where $f(x)=x^{13}+2x^{12}+3x^{11}+\cdots +13x+14$ and $\alpha=\cos\frac{2\pi}{15}+i\sin\frac{2\pi}{15}$. The answer given in the book is $15^{13}$. To find this value, we first note that the fourteen numbers in the set $A=\{\alpha,\alpha ^2, \ldots, \alpha ^{14}\}$ are all roots of the 15th degree equation
DrunkenOldFool
Let $f(x)=x^{13}+2x^{12}+3x^{11}+\cdots +13x+14$ and $\alpha=\cos\frac{2\pi}{15}+i\sin\frac{2\pi}{15}$. Find the value of $f(\alpha)f(\alpha ^2) \cdots f(\alpha ^{14})$.
(the answer given in my book is 15^(13)).
Please help me! I beg of you...
Firstly, the fourteen numbers in the set $A \overset{\text{def}}{=}\{ \alpha,\alpha ^2, \ldots, \alpha ^{14}\}$ are all roots of the 15th degree equation $x^{15} = 1$, the fifteenth root being $x=1.$
The next step is to find a more convenient form for the function $f(x)$. Start with the fact that $1+z+z^2 + \ldots + z^{14} = \dfrac{1-z^{15}}{1-z}.$ Differentiate, to get $$1+2z+3z^2+\ldots+14z^{13} = \frac{-15z^{14}(1-z)+(1-z^{15})}{(1-z)^2} = \frac{1-15z^{14}+14z^{15}}{(1-z)^2}.$$ Now divide through by $z^{13}$ and let $x = 1/z$, to get $$f(x) = x^{13}+2x^{12}+3x^{11}+\ldots +13x+14 = \frac{x^{15}-15x+14}{(1-x)^2}.$$ If $x^{15}=1$ (but $x\ne1$) then that becomes $f(x) = \dfrac{15(1-x)}{(1-x)^2} = \dfrac{15}{1-x}.$
So we are looking for the product $$\prod_{x\in A}f(x) = \prod_{x\in A}\frac{15}{1-x} = \frac{15^{14}}{\prod_{x\in A}(1-x)}.$$ For $x\in A$, let $w=1-x.$ Then $(1-w)^{15} = x^{15}=1.$ But $(1-w)^{15} = 1-15w+\ldots -w^{15}$, and the equation $(1-w)^{15} =1$ becomes $w^{15} - \ldots +15w = 0$. Divide by $w$ to eliminate the root $w=0$ (which corresponds to $x=1$) and we get $w^{14} - \ldots + 15=0.$ The product of the roots of this equation is 15, in other words $\prod_{x\in A}(1-x)=15.$ Combine that with the previous result to get $\prod_{x\in A}f(x) = 15^{13}.$
Thank you very much, sir!
To Opalg: (Bow)
-Dan
FAQ: Evaluating $f(\alpha)f(\alpha^2)...f(\alpha^{14})$
What is the purpose of evaluating f(\alpha)f(\alpha^2)...f(\alpha^{14})?
The purpose of evaluating this function is to determine the value of the expression by plugging in different values for alpha and applying the function f to each of them.
What is the significance of using alpha as the variable in this expression?
Alpha is a commonly used variable in mathematics and science, often representing a variable or unknown value. In this expression, alpha is used to represent a series of values that can be plugged into the function f.
How many times do you have to evaluate the function f for this expression?
In this expression, the function f needs to be evaluated 14 times, as the value of alpha ranges from alpha to alpha^14.
Can the function f be any type of function, or does it have to be a specific type?
The function f can be any type of function, as long as it can be applied to the variable alpha. This could include simple arithmetic functions, trigonometric functions, or even more complex functions.
How does evaluating f(\alpha)f(\alpha^2)...f(\alpha^{14}) differ from evaluating a single function at a specific value?
Evaluating f(\alpha)f(\alpha^2)...f(\alpha^{14}) involves evaluating the function f at multiple values, while evaluating a single function at a specific value involves only plugging in one value for the variable. This allows for a range of values to be considered in the first expression, while the second expression provides a specific output for a specific input.
