zorro
- 1,384
I tried expanding e^x and evaluated the limit as 1.
The answer given is 0.
The limit of expanded e^x as x approaches 0 is equal to 1. This can be shown using the definition of a limit, where the limit of a function at a point is the value that the function approaches as the input approaches that point.
To evaluate the limit of expanded e^x at 0, you can use the Maclaurin series expansion for e^x, which is 1 + x + x^2/2! + x^3/3! + ... By plugging in 0 for x, you will get the value of 1 for the limit.
The limit of expanded e^x at 0 is equal to 1 because e^x is defined as the infinite sum of x^k/k!, where k goes from 0 to infinity. When x is equal to 0, all the terms in the sum except for the first term (which is 1) become 0. Therefore, the limit becomes 1.
Yes, the limit of expanded e^x at 0 can be evaluated using L'Hospital's rule, which states that the limit of a fraction of two functions can be found by taking the limit of the derivatives of the numerator and denominator. In this case, the limit can be found by taking the limit of the derivative of e^x, which is e^x, and the derivative of x, which is 1. This also results in a limit of 1.
The limit of expanded e^x at 0 is equal to the derivative of e^x evaluated at 0. This is because the derivative of e^x is equal to e^x, and when x is equal to 0, the derivative of e^x is also equal to 1. This can be seen from the graph of e^x, where the slope of the tangent line at x=0 is equal to 1.
