Evaluating $M+N$ Given Triangle Congruency and Side Lengths
  • MHB
  • Thread starter anemone
  • Tags
    Triangle
In summary, given that triangle $ABC$ is congruent to triangle $CDE$, and that $\angle A=\angle B=80^{\circ}$, $AC=1$ and DG=\frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}. $M+N=-1$
anemone
MHB
POTW Director
3,883
115
Given that triangle $ABC$ is congruent to triangle $CDE$, and that $\angle A=\angle B=80^{\circ}$. Suppose that $AC=1$ and \(\displaystyle DG=\frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}\).
Evaluate $M+N$.
Mathematics news on Phys.org
Re: Evaluate M+N
My solution:
We find that:
\(\displaystyle \angle C=180^{\circ}-2\cdot80^{\circ}=20^{\circ}\)
The Law of Cosines gives us:
\(\displaystyle \overline{CD}^2=2\left(1-\cos\left(20^{\circ} \right) \right)\)
Triangle $CDG$ is similar to the two congruent triangles, hence, we may state:
\(\displaystyle \frac{\overline{CD}}{\overline{DG}}= \frac{1}{\overline{CD}}\implies\overline{DG}= \overline{CD}^2= 2\left(1-\cos\left(20^{\circ} \right) \right)\)
Using a double angle identity for cosine, we may write:
\(\displaystyle \overline{DG}=2\left(1-\left(1-2\sin^2\left(10^{\circ} \right) \right) \right)=4\sin^2\left(10^{\circ} \right)\)
Thus, we see that we require:
\(\displaystyle M+N\sin^2\left(10^{\circ} \right)=\frac{1}{2}\csc^3\left(10^{\circ} \right)\)
With $M=0$, we then have \(\displaystyle M+N=\frac{1}{2}\csc^3\left(10^{\circ} \right)\)
Re: Evaluate M+N
[sp]I agree with Mark as far as the line $DG = 4\sin^210^\circ$. But I wanted to express that in the form \(\displaystyle DG=\frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}\), with $M$ and $N$ numerical constants (not involving $\sin10^\circ$). So I want to find $M$ and $N$ such that \(\displaystyle 4\sin^210^\circ = \frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}\), or $2M\sin10^\circ + 2N\sin^310^\circ = 1$.
Remembering that $\sin3\theta = 3\sin\theta - 4\sin^3\theta$ and that $\sin30^\circ = 1/2$, I put $\theta = 10^\circ$, to get $\frac12 = 3\sin10^\circ - 4\sin^310^\circ$. Thus $6\sin10^\circ - 8\sin^310^\circ = 1$. Comparing that with the equation in the previous paragraph, you see that we can take $M=3$, $N=-4$ and hence $M+N = -1$.[/sp]
Re: Evaluate M+N
MarkFL said:
My solution:
We find that:
Hi MarkFL,
Thanks for participating and since the problem doesn't mention any restriction on the variables $M$ and $N$, you got the full credit for your solution! Bravo!
But even though I am not the question setter, I should have noticed when I solved the problem that I should add the condition on both variables so that their sum is unique. I admit I overlooked this. I'm sorry...:eek:
Hi Opalg,
Thanks for participating and I must tell you when I arrived at the step where I got $2Q\sin^3 10^{\circ}+2P \sin 10^{\circ}-1=0$, I immediately thought of the triple angle formula for the function of sine and you're recent help to me in one of the simultaneous equation threads was the inspiration to me...so, I wouldn't have solved this problem if not for what you have taught me! (Sun)
I would first like to clarify that the given information is not sufficient to evaluate $M+N$. In order to find the value of $M+N$, we need to have more information about the triangles $ABC$ and $CDE$, such as their side lengths or angles.
However, based on the given information, we can make some observations. Since triangle $ABC$ is congruent to triangle $CDE$, we can conclude that $AB=CD$ and $BC=DE$. Also, since $\angle A=\angle B=80^{\circ}$, we can infer that $\angle C=\angle D=100^{\circ}$, as all angles in a triangle must add up to $180^{\circ}$.
Using the Law of Sines, we can write the following equations:
$\frac{AC}{\sin \angle C}=\frac{BC}{\sin \angle B}$ and $\frac{DG}{\sin \angle D}=\frac{CG}{\sin \angle C}$
Substituting the known values, we get:
$\frac{1}{\sin 100^{\circ}}=\frac{BC}{\sin 80^{\circ}}$ and $\frac{\frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}}{\sin 100^{\circ}}=\frac{CG}{\sin 100^{\circ}}$
Simplifying these equations, we get:
$BC=\frac{\sin 80^{\circ}}{\sin 100^{\circ}}$ and $CG=\frac{2\sin 10^{\circ}}{M+N\sin^2 10^{\circ}}$
Again, we cannot solve for $M+N$ without more information. However, we can make some observations about the value of $M+N$ based on the given equation for $DG$. We can see that $M+N$ must be a positive value, as $\sin^2 10^{\circ}$ is always positive and $DG$ is given to be a positive value. Additionally, as $\sin 10^{\circ}$ is a small value, $M+N$ must be a large value in order for the fraction to be small.
In conclusion, based on the given information, we cannot evaluate $M+N$ accurately. We would need more information about the
FAQ: Evaluating $M+N$ Given Triangle Congruency and Side Lengths
How do you determine if two triangles are congruent?
Two triangles are congruent if all three corresponding sides are equal in length.
What is the significance of triangle congruency in evaluating $M+N$?
Triangle congruency allows us to use the properties of congruent triangles, such as corresponding angles and side lengths, to determine the value of $M+N$.
Can you use triangle congruency to evaluate $M+N$ if only the side lengths are given?
Yes, if the side lengths of two triangles are equal, then the triangles are congruent and we can use this information to evaluate $M+N$.
Are there any other methods besides triangle congruency to evaluate $M+N$ given side lengths?
Yes, we can also use the Pythagorean theorem and trigonometric functions to evaluate $M+N$ in certain cases where the given side lengths form a right triangle.
What should be done if there is not enough information to determine triangle congruency?
If there is not enough information to determine triangle congruency, we can try to find more information by using other geometric theorems or postulates. If necessary, we can also use algebraic equations to solve for missing values.
