Evaluating magnitude of vector
In summary, the conversation discusses finding the value of c given two unit vectors a and b, where |a+b| = √3. By using the definition and properties of axb, the angle between a and axb or between b and axb can be determined to be 90°. By expanding the expression for |c|^2, with the dot product, the value of c can be evaluated to be √55.
Raghav Gupta
1,011
76
Let a and b be two unit vectors such that | a + b| = √3. If
c = a+ 2b + 3(a x b), then 2|c| is equal to:
√55
√51
√43
√37
a x b = |a| |b| sinθ n where n is a unit vector
## | a + b | = \sqrt{a^2 + b^2 + 2abcosθ} ##
Found cosθ = 1/2 and θ = π/3
Then 3 a x b = 3√3/2 n
Now how to find c?
We don't know angle between n and a or n and b
√55
√51
√43
√37
Now how to find c?
Yes, you do know the angle. Go back and review the definition and properties of axb.
I know angle is π/3
What to do next?
I have also written value of a x b in attempt in post 1
Raghav Gupta said:
I know angle is π/3
What to do next?
No. The angle between a and b is π/3, but that is not the angle you asked about. You asked about the angle between a and axb or between b and axb.
Oh that is 90°. But how I will evaluate c?
What is preventing you from writing out all the terms of |c|^2 and evaluating them one-by-one? In other words, use the fact that
$$ |\vec{c}|^2 = \vec{c} \cdot \vec{c} \\
= (\vec{a} + 2\vec{b} +3\, \vec{a} \times \vec{b}) \cdot (\vec{a} + 2\vec{b} +3\, \vec{a} \times \vec{b}) $$
and just expand it all out.
Likes Raghav Gupta
## |c|^2 = (a+2b)^2 + [3( a X b )]^2 + 2( a+2b)3( a X b ) cos θ ##
What is the angle between (a+ 2b) and a x b ?
Between a and a x b it is 90°.
what does the dot product of the two yield?
Likes Raghav Gupta
It yields 0, so the angle is 90°?
Yes.
You have not "expanded it all out"; you should be getting 6 terms, not just the 3 you have written.
Got it on solving.
Thanks to both of you.
FAQ: Evaluating magnitude of vector
1. What is a vector?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is typically represented by an arrow pointing in the direction of the vector with its length representing the magnitude.
2. How do you calculate the magnitude of a vector?
The magnitude of a vector is calculated using the Pythagorean theorem, which states that the magnitude is equal to the square root of the sum of the squares of the vector's components. In other words, you square the x-component of the vector, square the y-component, add the two values, and then take the square root of the result.
3. What units are used to measure vector magnitude?
The units used to measure vector magnitude depend on the type of vector being measured. For example, velocity vectors are measured in meters per second, force vectors are measured in newtons, and electric field vectors are measured in volts per meter.
4. Can a vector have a negative magnitude?
No, a vector's magnitude is always a positive value. However, the direction of the vector can be negative if it is pointing in the opposite direction of a positive reference axis.
5. How does vector addition affect the magnitude of a vector?
When two vectors are added together, the resulting vector will have a magnitude that is equal to the sum of the magnitudes of the individual vectors. This means that vector addition can increase or decrease the magnitude of a vector depending on the direction and magnitude of the added vector.
