MHB Evaluating Sum Compute: n+1 Roots
  • Thread starter Thread starter anemone
    Sum
The discussion focuses on computing the expression $$\left\lfloor{\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}}\right\rfloor$$. Participants clarify that the goal is to find the floor of the sum of these roots. The conversation highlights the importance of correctly interpreting the mathematical notation and the implications for the final result. There is acknowledgment of a previous misunderstanding regarding the problem's requirements. The thread emphasizes the significance of precision in mathematical computations.
anemone
MHB
POTW Director
Compute $$\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}$$.
Mathematics news on Phys.org
anemone said:
Compute $$\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}=S$$.
it should be :
for any $n$
$n<S<n+1$
Albert said:
it should be :
for any $n$
$n<S<n+1$
Ops! You're right, and the problem is actually asked to compute $$
\left\lfloor{\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}}\right\rfloor$$.:o
We have for t positive integer
$(1+x)^{t+1} > 1 + x(t+1)$
or $(1+x) > \sqrt[t+1]{1 + x(t+1)}$
putting $x = \frac{1}{t(t+1)}$ we get
$1+\frac{1}{t(t+1)} > \sqrt[t+1]{1 + \frac{1}{t}}$
or $1+\frac{1}{t(t+1)} > \sqrt[t+1]{\frac{t+1}{t}}$
or $1+\frac{1}{t} - \frac{1}{t+1} > \sqrt[t+1]{\frac{t+1}{t}}$
adding the above from t = 1 to n we get
${\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}} <n + 1 - \frac{1}{n+1}$
as each term is greater than one we have
${\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}} > n $
as the value is between n and n + 1 so
$\left\lfloor{\sqrt[n+1]{\frac{n+1}{n}}+\sqrt[n]{\frac{n}{n-1}}+\cdots+\sqrt[4]{\frac{4}{3}}+\sqrt[3]{\frac{3}{2}}+\sqrt{2}}\right\rfloor = n $
I privately told anemone that the answer was $n$, but I was told I must show my work. (Crying)
Very well done, kaliprasad!(Cool)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
