Evaluating Summation: Find $\sum_{i=1}^{\infty} (-1)^{i+1}f(i)$
  • MHB
  • Thread starter Saitama
  • Tags
    Summation
In summary, evaluating summation is a mathematical method used to find the sum of an infinite series or sequence of numbers. It is represented by the symbol "∑" and can be evaluated using various methods. The term "f(i)" in the summation notation represents a function of the variable i. The sum of an infinite series can be negative, positive, zero, or undefined.
Saitama
4,243
93
Problem:
Consider a function $f(n)$ defined as:
$$f(n)=\sum_{r=1}^n (-1)^{r+1} \binom{n}{r} \left(\sum_{k=1}^r \frac{1}{k}\right)$$
Find the value of
$$\sum_{i=1}^{\infty} (-1)^{i+1}f(i)$$
Attempt:
I write $\sum_{k=1}^r (1/k)=H_r$.
The sum I have to evaluate is
$$f(1)-f(2)+f(3)-f(4)+\cdots$$
I tried writing down a few terms and tried to see the difference of consecutive terms...
$$f(1)=H_1$$
$$f(2)=2H_1-H_2$$
$$f(3)=3H_1-3H_2+H_3$$
$$f(4)=4H_1-6H_2+4H_3+H_4$$
...but I don't see if this helps.
Although I have posted this in the Pre-Algebra and Algebra forum, please feel free to use any Calculus approaches as I am not sure if the problem involves the use of Calculus.
Any help is appreciated. Thanks!
Mathematics news on Phys.org
Pranav said:
Problem:
Find the value of
Attempt:
$$f(1)=H_1$$
$$f(2)=2H_1-H_2$$
Your approach is very good because is... $f(1) = H_{1} = 1$
$f(2) = 2\ H_{1} - H_{2} = 2 - 1 - \frac{1}{2} = \frac{1}{2}$
$f(3) = 3\ H_{1} - 3\ H_{2} + H_{3} = 3 - 3 - \frac{3}{2} + 1 + \frac{1}{2} + \frac{1}{3} = \frac{1}{3}$ ... and proceeding in this way You arrive at the very suggestive relation...
$\displaystyle f(n) = \sum_{k=1}^{n} (-1)^{k+1} \binom{n}{k}\ H_{k} = \frac{1}{n}\ (1)$... so that is...$\displaystyle \sum_{i=1}^{\infty} (-1)^{i + 1} f(i) = \ln 2\ (2)$
Kind regards
$\chi$ $\sigma$
Switch the order of the inner sums and use $\displaystyle \sum\limits_{k \le r \le n} (-1)^r\binom{n}{r} = \frac{k (-1)^k}{n} \binom{n}{k}.$
$$\displaystyle \begin{aligned} \sum_{n \ge 1}\sum_{1 \le r \le n} \sum_{1 \le k \le r} \frac{(-1)^{n+r}}{k} \binom{n}{r} & = \sum_{n \ge 1}\sum_{1 \le k \le n} \sum_{k \le r \le n} \frac{(-1)^{n+r}}{k} \binom{n}{r} \\& = \sum_{n \ge 1}\sum_{1 \le k \le n}\frac{(-1)^{k+n}}{n} \binom{n}{k} \\& = \sum_{n \ge 1} \frac{(-1)^{n+1}}{n} \\& = \log(2).\end{aligned} $$​
@Prometheus
Could you give a proof of that identity?
Kind regards
$\chi$ $\sigma$
Awesome! :cool:
I never thought I was so close to the answer, thanks a lot chisigma! :)
Random Variable said:
There is a proof that $ \displaystyle H_{n} = \sum_{k=1}^{n}(-1)^{k-1} \binom{n}{k} \frac{1}{k} $ on Wikipedia page for the harmonic numbers.
Harmonic number - Wikipedia, the free encyclopediaThen by applying the inverse binomial transform,
$$ \frac{1}{n} = \sum_{k=1}^{n} (-1)^{k-1} \binom{n}{k} H_{k} $$Binomial Transform -- from Wolfram MathWorld
Hi Random Variable, thank you very much for your input. :)
I have never heard of inverse binomial transform before but it looks like a useful technique. I seem to have trouble figuring out how did you use it here.
We have
$$H_{n} = \sum_{k=1}^{n}(-1)^{k-1} \binom{n}{k} \frac{1}{k} $$
From the Wolfram page you quote, $b_n$ should be of the form $\displaystyle \sum_{k=0}^n (-1)^{n-k} a_k$ but I have $(-1)^{k-1}$ instead of $(-1)^{n-k}$. :confused:
Sorry if this is silly but I have never seen that representation of $H_n$ and the binomial transform. :eek:
Thanks!
@ PranavFirst let $a_{0}=b_{0} = 0 $.
Then multiply both sides of $ \displaystyle H_{n} = \sum_{k=1}^{n} (-1)^{k-1} \binom{n}{k} \frac{1}{k} $ by $(-1)^{n+1}$.
Then $ \displaystyle (-1)^{n+1} H_{n} = (-1)^{n-1} H_{n} = \sum_{k=1}^{n} (-1)^{n+k} \binom{n}{k} \frac{1}{k} = \sum_{k=1}^{n} (-1)^{n-k} \binom{n}{k} \frac{1}{k}$.
Now take the inverse binomial transform.
Thanks a lot Random Variable! :)
FAQ: Evaluating Summation: Find $\sum_{i=1}^{\infty} (-1)^{i+1}f(i)$
What is the purpose of evaluating summation?
Evaluating summation is used to find the sum of an infinite series, or a sequence of numbers that continues indefinitely. This can help in solving various mathematical problems and understanding patterns in data.
What does the notation "∑" mean in evaluating summation?
The symbol "∑" represents the summation operator, which indicates that the terms within the summation should be added together.
How do you evaluate infinite summations?
Infinite summations can be evaluated using various methods, such as the geometric series formula, telescoping series, or the ratio test. It is important to analyze the series and determine if it converges or diverges before attempting to evaluate it.
What does the term "f(i)" represent in the summation notation?
The term "f(i)" represents a function of the variable i. This means that for each value of i, there is a corresponding value of f(i) that is being added to the summation.
Can the sum of an infinite series be negative?
Yes, the sum of an infinite series can be negative if the terms being added have alternating signs. For example, the series ∑ (-1)^n converges to -1. However, it is important to note that the sum of an infinite series can also be positive, zero, or undefined.
