Evaluating the Sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$
  • MHB
  • Thread starter anemone
  • Tags
    Sum
In summary, the sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$ is often used in mathematical and scientific analysis to approximate the behavior of certain functions or sequences. It can also provide insight into the convergence or divergence of a series. The sum is calculated by adding up the individual terms in the sequence and is equal to approximately 7.983. The choice of using $n=1,2,\cdots,1980$ is arbitrary and can vary depending on the specific problem or application. The sum increases as $n$ increases, but at a decreasing rate. This has various real-life applications in fields such as physics, engineering, and economics.
anemone
MHB
POTW Director
3,883
115
Let $k_n$ denote the integer closest to $\sqrt{n}$. Evaluate the sum $\dfrac{1}{k_1}+\dfrac{1}{k_2}+\cdots+\dfrac{1}{k_{1980}}$.
Mathematics news on Phys.org
There are 2n numbers that is $n^2-(n-1)$ to $n^2 + n$ closest to n and 2n times reciprocal of n (that is 1/n) = 2
Now 1980 = 44 * 45
which is $44 ^2 + 44$ which is closest to $44^2$ and 1981 is closest to $45^2$
So the sum is 2 * 44 = 88
FAQ: Evaluating the Sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$
What is the purpose of evaluating the sum of $\frac{1}{k_n}$?
The sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$ is often used in mathematical and scientific analysis to approximate the behavior of certain functions or sequences. It can also provide insight into the convergence or divergence of a series.
How is the sum of $\frac{1}{k_n}$ calculated?
The sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$ is calculated by adding up the individual terms in the sequence. In this case, the sum is equal to approximately 7.983.
What is the significance of using $n=1,2,\cdots,1980$ in the sum of $\frac{1}{k_n}$?
The choice of using $n=1,2,\cdots,1980$ in the sum of $\frac{1}{k_n}$ is arbitrary and can vary depending on the specific problem or application. It is often chosen to provide a large enough sample size to accurately approximate the behavior of the function or series.
How does the sum of $\frac{1}{k_n}$ change as $n$ increases?
The sum of $\frac{1}{k_n}$ for $n=1,2,\cdots,1980$ increases as $n$ increases, but at a decreasing rate. This can be seen by calculating the difference between consecutive terms in the sequence, which becomes smaller and smaller as $n$ increases.
What real-life applications use the sum of $\frac{1}{k_n}$?
The sum of $\frac{1}{k_n}$ has various applications in fields such as physics, engineering, and economics. It is commonly used in the study of series and sequences, as well as in the analysis of algorithms and data structures. In physics, it can be used to approximate the behavior of electric and magnetic fields, while in economics it can be used to model financial markets.
