Evaluating X/Y: A Series of Fractions
In summary, the purpose of evaluating X/Y: A Series of Fractions is to determine the value of a fraction or a series of fractions, which can be useful in mathematical and scientific calculations. To evaluate a fraction, one needs to divide the numerator by the denominator. Proper fractions have a smaller numerator, while improper fractions have a larger or equal numerator to the denominator. To evaluate a series of fractions, follow the order of operations. Fractions can be evaluated with negative numbers, where a negative numerator makes the fraction negative and a negative denominator makes it positive.
anemone
MHB
POTW Director
3,883
115
Let \(\displaystyle X=\frac{1}{1\cdot2}+\frac{1}{3\cdot4}+\cdots+\frac{1}{2011\cdot2012}\) and \(\displaystyle Y=\frac{1}{1007\cdot2012}+\frac{1}{1008\cdot2011}+\cdots+\frac{1}{2012\cdot1007}\).
Evaluate \(\displaystyle \frac{X}{Y}\).
Mathematics news on Phys.org
My solution:
\(\displaystyle \;\;\;=\sum_{n=1}^{1006} \left( \frac{1}{2n-1}-\frac{1}{2n} \right)\)
\(\displaystyle \;\;\;=\left( \frac{1}{1}-\frac{1}{2} \right)+\left( \frac{1}{3}-\frac{1}{4} \right)+\cdots+\left( \frac{1}{2011}-\frac{1}{2012} \right)\)
Okay, up to this point, we see $X$ and $Y$ aren't closely related so we need to begin to work on $Y$ to gain perspective to see how we should proceed to solve the problem.
\(\displaystyle \;\;\;=\sum_{n=1}^{1006} \frac{1}{3019}\left( \frac{1}{n+1006}+\frac{1}{2013-n} \right)\)
\(\displaystyle \;\;\;=\frac{1}{3019} \sum_{n=1}^{1006} \left( \frac{1}{n+1006}+\frac{1}{2013-n} \right)\)
\(\displaystyle \;\;\;=\frac{1}{3019} \left( \left( \frac{1}{1007}+\frac{1}{2012} \right)+ \left( \frac{1}{1008}+\frac{1}{2012} \right)+\cdots+\left( \frac{1}{2012}+\frac{1}{1007} \right)\right)\)
\(\displaystyle \;\;\;=\frac{2}{3019} \left( \frac{1}{1007}+\frac{1}{1008}+\cdots+\frac{1}{2011}+\frac{1}{2012} \right)\)
Hey, now everything has become so obvious that
\(\displaystyle \left( \frac{1}{1007}+\frac{1}{1008}+\cdots+\frac{1}{2011}+\frac{1}{2012} \right)=\left( \frac{1}{1}-\frac{1}{2} \right)+\left( \frac{1}{3}-\frac{1}{4} \right)+\cdots+\left( \frac{1}{2011}-\frac{1}{2012} \right)\)
and therefore
\(\displaystyle Y=\frac{2X}{3019}\)
\(\displaystyle \frac{X}{Y}=\frac{3019}{2}\)
FAQ: Evaluating X/Y: A Series of Fractions
What is the purpose of evaluating X/Y: A Series of Fractions?
The purpose of evaluating X/Y: A Series of Fractions is to determine the value of a fraction or a series of fractions. This can be useful in various mathematical and scientific calculations.
How do you evaluate a fraction?
To evaluate a fraction, you need to divide the numerator (top number) by the denominator (bottom number). The resulting number is the value of the fraction.
What is the difference between a proper fraction and an improper fraction?
A proper fraction is a fraction where the numerator is smaller than the denominator, while an improper fraction has a numerator that is equal to or larger than the denominator.
How do you evaluate a series of fractions?
To evaluate a series of fractions, you need to follow the order of operations. Start by simplifying any fractions within the series, then add or subtract the fractions from left to right, and finally, multiply or divide the fractions from left to right.
Can fractions be evaluated with negative numbers?
Yes, fractions can be evaluated with negative numbers. When working with negative fractions, remember that a negative numerator makes the fraction negative, while a negative denominator makes the fraction positive.
10K
10K
