Evaluation of definite integral (is it correct?)
In summary: Integration by parts:$$\begin{align*}\int\sinh^2(x)\,\text{d}x&=\sinh(x)\cosh(x)-x-\int\sinh^2(x)\,\text{d}x \\&=\sinh(x)\cosh(x)-x-\int\sinh^2(x)\,\text{d}x \\2\int\sinh^2(x)\,\text{d}x&=\sinh(x)\cosh(x)-x \\\int\sinh^2(x)\,\text{d}x&
Noah1
MarkFL said:
To find the intersection(s) in the given interval, we may write:
\(\displaystyle \sin(x)=\cos(x)\)
Now, observing that \(\displaystyle \cos\left(\frac{\pi}{2}\right)=\cos\left(\frac{3\pi}{2}\right)=0\) and:
\(\displaystyle \cos\left(\frac{\pi}{2}\right)\ne\sin\left(\frac{\pi}{2}\right)\)
\(\displaystyle \cos\left(\frac{3\pi}{2}\right)\ne\sin\left(\frac{3\pi}{2}\right)\)
We may then divide though by $\cos(x)$ without losing any solutions on the given interval to get:
\(\displaystyle \tan(x)=1\)
And, given the periodicity of the tangent function and the quadrant I solution of \(\displaystyle x=\frac{\pi}{4}\), we may give the general solution as:
\(\displaystyle x=\frac{\pi}{4}+k\pi=\frac{\pi}{4}(4k+1)\) where $k\in\mathbb{Z}$
Now, along with the given interval and what we found at the endpoints, we may write:
\(\displaystyle \frac{\pi}{2}<\frac{\pi}{4}(4k+1)<\frac{3\pi}{2}\)
\(\displaystyle 2<4k+1<6\)
\(\displaystyle 1<4k<5\)
\(\displaystyle \frac{1}{4}<k<\frac{5}{4}\)
Hence (given that $k$ is an integer):
$k=1$
And so the intersection of the two functions occurs for:
\(\displaystyle x=\frac{\pi}{4}(4(1)+1)=\frac{5\pi}{4}\)
Now, observing that:
\(\displaystyle \sin\left(\frac{\pi}{2}\right)>\cos\left(\frac{\pi}{2}\right)\)
\(\displaystyle \sin\left(\frac{3\pi}{2}\right)<\cos\left(\frac{3\pi}{2}\right)\)
We may conclude:
\(\displaystyle \sin(x)>\cos(x)\) on \(\displaystyle \left[\frac{\pi}{2},\frac{5\pi}{4}\right)\)
\(\displaystyle \cos(x)>\sin(x)\) on \(\displaystyle \left(\frac{5\pi}{4},\frac{3\pi}{2}\right]\)
And so the area $A$ in question will be given by:
\(\displaystyle A=\int_{\frac{\pi}{2}}^{\frac{5\pi}{4}} \sin(x)-\cos(x)\,dx+\int_{\frac{5\pi}{4}}^{\frac{3\pi}{2}} \cos(x)-\sin(x)\,dx=(1+\sqrt{2})+(\sqrt{2}-1)=2\sqrt{2}\)
Is this question correct? We are given to evaluate:
\(\displaystyle \int_0^2 \left(e^x-e^{-x}\right)^2\,dx\)
\(\displaystyle 2\left(\frac{1}{2}\sinh(x)-x\right)\)
\(\displaystyle 2\left(\frac{1}{2}\sinh(2\cdot2)-2\right)-2\left(\frac{1}{2}\sinh(2\cdot0)-0\right)\)
\(\displaystyle \sinh(4)-4\)
I have moved this post to its own thread, because we really don't want threads to become a series of one question after another. It is best for forum organization for each question to be in its own thread.
Your result is correct...I would have written essentially the same thing:
\(\displaystyle \int_0^2 \left(e^x-e^{-x}\right)^2\,dx=4\int_0^2 \sinh^2(x)\,dx=2\int_0^2 \cosh(2x)-1\,dx=2\left[\frac{1}{2}\sinh(2x)-x\right]_0^2=2\left(\frac{1}{2}\sinh(4)-2-\frac{1}{2}\sinh(0)+0\right)=\sinh(4)-4\)
$$\begin{align*}\int\sinh^2(x)\,\text{d}x&=\sinh(x)\cosh(x)-\int\cosh^2(x)\,\text{d}x \\
\int\sinh^2(x)\,\text{d}x&=\frac12(\sinh(x)\cosh(x)-x)+C\end{align*}$$
Or: \(\displaystyle \int_0^2 (e^x- e^{-x})^2 dx=\int_0^2 e^{2x}- 2+e^{-2x} dx=\left[\frac{1}{2}e^{2x}-2x- \frac{1}{2}e^{-2x}\right]_0^2= \left(\frac{e^4}{2}- 4- \frac{e^{-4}}{2}\right)\)
FAQ: Evaluation of definite integral (is it correct?)
What is a definite integral?
A definite integral is a mathematical concept used to calculate the area under a curve or the net accumulation of a quantity over a specific interval.
How do you evaluate a definite integral?
To evaluate a definite integral, you need to first find the antiderivative of the function in question. Then, substitute the upper and lower limits of the integral into the antiderivative and find the difference between the two values.
What is the purpose of evaluating a definite integral?
The purpose of evaluating a definite integral is to find the exact value of the area under a curve or the net accumulation of a quantity over a specific interval. This has many applications in various fields of science and engineering, such as calculating work done, finding the average of a function, and determining probabilities.
How do you know if your evaluation of a definite integral is correct?
To check if your evaluation of a definite integral is correct, you can use the Fundamental Theorem of Calculus, which states that the definite integral of a function is equal to the difference between the values of the antiderivative at the upper and lower limits of the integral. You can also use numerical methods, such as the trapezoidal or Simpson's rule, to estimate the value of the integral and compare it to your calculated result.
What are some common mistakes to avoid when evaluating a definite integral?
Some common mistakes to avoid when evaluating a definite integral include forgetting to find the antiderivative of the function, using the wrong limits of integration, and making calculation errors. It is also important to pay attention to the properties of integrals, such as linearity and the change of variables, to avoid mistakes in the evaluation process.
