spaghetti3451
- 1,344
- 34
Compute ##\displaystyle{\int\ \frac{d^{4}p}{(2\pi)^{4}}} \frac{i}{p^{2}-m^{2}+i\epsilon}e^{-ip \cdot{(x-y)}}## in terms of the invariant interval.
Interpret your answer in the limit of small and large invariant intervals and for zero mass.
##=\displaystyle{\int\ \frac{d^{4}p}{(2\pi)^{4}}} \frac{i}{(p^{0})^{2}-(E_{\vec{p}})^{2}+i\epsilon}e^{-ip \cdot{(x-y)}}##
##=\displaystyle{\int\ \frac{d^{4}p}{(2\pi)^{4}}} \frac{i}{(p^{0})^{2}-(E_{\vec{p}}-i\epsilon)^{2}}e^{-ip \cdot{(x-y)}}##
##=\displaystyle{\int\ \frac{d^{4}p}{(2\pi)^{4}}} \frac{i}{(p^{0}-(E_{\vec{p}}-i\epsilon))(p^{0}+(E_{\vec{p}}-i\epsilon))}e^{-ip \cdot{(x-y)}}##
Therefore, the contour prescription ##i\epsilon## reminds us to integrate under the pole at ##p^{0}=-E_{\vec{p}}## and over the pole at ##p^{0}=E_{\vec{p}}##. So, let's now drop the ##i\epsilon## term and obtain
##=\displaystyle{\int\ \frac{d^{4}p}{(2\pi)^{4}}} \frac{i}{(p^{0}-E_{\vec{p}})(p^{0}+E_{\vec{p}})}e^{-ip \cdot{(x-y)}}##
##=\displaystyle{\int\ \frac{d^{3}p}{(2\pi)^{3}}}\ \bigg[ \int\ \frac{dp^{0}}{2\pi} \frac{i}{(p^{0}-E_{\vec{p}})(p^{0}+E_{\vec{p}})}e^{-ip^{0}(x^{0}-y^{0})} \bigg]\ e^{-ip^{i}(x_{i}-y_{i})}##
For ##x^{0}>y^{0}##, we close the contour below (clockwise sense introduces a negative factor) and for ##x^{0}<y^{0}##, we close the contour above (anti-clockwise sense introduces a positive factor), so that
##=\displaystyle{\int\ \frac{d^{3}p}{(2\pi)^{3}}}\ \bigg[ \theta(x^{0}-y^{0})\frac{1}{2E_{\vec{p}}}e^{-iE_{\vec{p}}(x^{0}-y^{0})} +\theta(y^{0}-x^{0})\frac{1}{-2E_{\vec{p}}}e^{iE_{\vec{p}}(x^{0}-y^{0})} \bigg]\ e^{-ip^{i}(x_{i}-y_{i})}##
Am I correct so far?
