MHB Evaluation of Infinite sum of Inverse Trig. Series.
The discussion focuses on proving the infinite sum of the series involving inverse tangent functions, specifically showing that the sum equals \(\frac{\pi}{4} + \cot^{-1}(3)\). The initial attempt involved calculating the \(n^{th}\) term of the series, which was incorrectly identified as \(4n^2 - 8n + 7\). A participant corrected this to \(4n^2 + 3\) and provided a reformulation of the series as a telescoping series. The final suggestion indicates that the telescoping nature of the series simplifies the evaluation process significantly. The conversation emphasizes the importance of correctly identifying the general term for accurate summation.
juantheron
How can we prove $$\displaystyle \tan^{-1}\left(\frac{4}{7}\right)+\tan^{-1}\left(\frac{4}{19}\right)+\tan^{-1}\left(\frac{4}{39}\right)+\tan^{-1}\left(\frac{4}{67}\right)+...\infty = \frac{\pi}{4}+\cot^{-1}(3)$$
My Trial: First we will calculate $\bf{n^{th}}$ terms of Given Series, $$7,19,39,76$$
I have got $4n^2-8n+7$
So we can Write the given series as $$\displaystyle \lim_{n\rightarrow \infty}\sum_{r=1}^{n}\tan^{-1}\left(\frac{4}{4n^2-8n+7}\right)$$
But I did not understand how can i solve it
Help me
Thanks
Mathematics news on Phys.org
Help me
Thanks
Your general term isn't correct. $4n^2+3$ fits better.
So,you have to evaluate the following sum:
$$\sum_{r=1}^{\infty} \arctan\left(\frac{4}{4r^2+3}\right)=\sum_{r=1}^{\infty} \arctan\left(\frac{1}{r^2+3/4}\right)=\sum_{r=1}^{\infty} \arctan\left(\frac{(r+1/2)-(r-1/2)}{1+(r+1/2)(r-1/2)}\right)$$
$$=\sum_{r=1}^{\infty} \arctan\left(r+\frac{1}{2}\right)-\arctan\left(r-\frac{1}{2}\right)$$
This is a telescoping series which should be easy to evaluate.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
