Evaporation of organic solvent and leftover residue
In summary, using air evaporation to remove solvent from a sample before spectroscopy may interfere with the spectrum of the compound being analysed.
~christina~
I have a question about evaporation of organic solvents and the leftover sample after this is done. (sample dissolved in the organic solvent)
Does the sample, leftover after the evaporation of a organic solvent, (used to dissolve the sample) affect the analysis of the dry sample? (basically, would there still be leftover organic solvent left, or does it all evaporate off? and thus not affect the sample analysis)
This question applies to two situations I have:
1. I have to run a TLC plate and I was wondering if the organic solvent used to dissolve the compound mattered, since you evaporate it off before you run the plate. Does it affect the run?
2. Would there be a residual leftover of organic solvent on the sample after evaporation that would affect the spectrum of the compound when run on a KBr pellet in IR spectroscopy?
Thank you.
Chemistry news on Phys.org
In general there should be no problems.
It wouldn't be very surprising if in some very rare cases simple evaporation will be not enough, but IMHO you will be very (un)lucky to have to deal with such a situation.
Thanks a lot Borek :smile:
Thank you.
In my experience, and I'm a professional chemist, you almost always have residual organic solvent in your sample unless you take pains to remove it thoroughly. Simple evaporation almost never removes all of the solvent unless the compound crystallizes.
OK, I stand corrected :redface:
What I was aiming at was that in my experience (past experience I must add) solvent was never a problem when preparing spectra. Sure, if you are using spectroscopy to determine contaminants, you may easily detect solvent left, but - if that's the risk - you will never use this solvent in the first place. When you use solvent for extraction, or for reaction - it usually doesn't interfere.
Or is my experience abnormal?
You need to dry a compound for at least 24 hours over night in a vacuum oven if you want a clean NMR without any traces of solvent.
http://img5.imageshack.us/img5/4596/shockedb.gif Darn, I thought that it would leave a residue.
Situation: unknown compound(s) dissolved in solvent(s) and thus I have to evaporate solvent off before being able to analyse compound(s). I want to use TLC to run, solvent + compound to determine number of compounds in liquid. Then of course evaporate the solvent off if it's one compound and extract if it's more than one compound. Finally I want to, evaporate solvent off and make KBr pellet and run in IR spectrometer.
Note: Using AIR evaporation in fume hood
The big question is, (for anyone who can answer this)
1. Will it make it difficult to determine the spectra of an unknown compound if there is
residual solvent leftover, when analysing the spectra through KBr pellet method?
2. Does solvent used to dissolve compound and run TLC plate matter since it evaporates? (I
want to run the TLC plate preferably without using GC to find exact solvent first, to see
how many drugs are in unknown liquid)
I don't know what the solvent is and I really haven't encountered having to evaporate liquid samples to obtain a powder form of a compound. This is the reason I don't know how a IR spectra will be affected by leftover solvent residue from just air evaporation.
Well the problem is that I don't have the availability to place something in an oven overnight and we don't have a vacuum oven, so I'm planning to use air evaporation in the fume hood.
Thanks
Christina asked about IR pellets which implies that she is working with a solid. You are correct that the residual solvent won't usually interfere with an IR determination. There are some exceptions I could come up with but I'd be reaching if I called that the usual experience. If a student were trying, for example, to make a ketone or carboxylic acid from an alcohol for the first time, he or she might be confused in their interpretation of an IR spectrum if solvent peaks are present. An alcohol (starting material) has an OH stretch that would interfere with the OH absorption of water if that was used in the workup - extraction. Likewise the carbonyl stretch of a solvent like ethyl acetate might be confused with the carbonyl stretch from the expected product likely producing two closely-spaced absorbances and leading to confusion in the interpretation.
~christina~ said:
The big question is,(for anyone who can answer this)
For IR, probably not but be aware that you are usually only looking at certain functional groups in the IR. Keep in mind what type(s) of solvents you used that might interfere.
2. Does solvent used to dissolve compound and run TLC plate matter since it evaporates? (I want to run the TLC plate preferably without using GC to find exact solvent first, to see how many drugs are in unknown liquid)[/B]
If the evaporation leaves an oily residue, expect significant interferences.
TLC is usually no problem since you are spotting them from solution anyway.
We are using the fingerprint region of the spectrum and comparing that with known fingerprint region spectra of known compounds in a database.
Define, "oily residue." I'm not sure how that would look like.
Thank you
Like goo.
Borek said:
Like goo.
i.e. not powdery?
Generally - not solid. Most likely you will have a drop of something that looks like oil.
okay, Thanks Borek. :smile:
FAQ: Evaporation of organic solvent and leftover residue
What is evaporation of organic solvent and leftover residue?
Evaporation of organic solvent and leftover residue is a process in which a liquid solvent, such as water, is heated and converted into a gas, leaving behind any solid or dissolved substances, known as residue.
How does evaporation of organic solvent and leftover residue occur?
This process occurs when the solvent is heated to its boiling point, causing the molecules to gain enough energy to break free from each other and escape into the surrounding air. The residue is left behind as the solvent molecules evaporate.
What are the factors that affect the rate of evaporation of organic solvent and leftover residue?
The rate of evaporation depends on factors such as temperature, surface area, and air flow. Higher temperatures, larger surface areas, and increased air flow can all speed up the evaporation process.
Can evaporation of organic solvent and leftover residue be controlled?
Yes, the rate of evaporation can be controlled by adjusting the temperature, surface area, and air flow. Additionally, using a vacuum or applying pressure can also affect the rate of evaporation.
What are the applications of evaporation of organic solvent and leftover residue in scientific research?
Evaporation of organic solvent and leftover residue is commonly used in various laboratory techniques such as recrystallization, chromatography, and distillation. It is also used in industries to separate and purify substances.
