Even another 2-slit experiment setup
In summary, if you have two sources of entangled photons that emit one to the left and one to the right, and you can vary the distance between the two screens so that an interference pattern can be seen on one screen, then it seems as though the which path information is carried by the left hand photons and it is possible to extract this information without measuring the right hand one directly.
Nacho
164
I'm interested in knowing what would happen in this setup, if anybody knows. I don't have a way to make a diagram, but the setup is pretty easy.
Say that in a central location, call it L, you have a source of entangled photons that emit one to the left side and the other to the right side 180 degrees away. I don't know if you need beam splitters to make it work, but we can put some in anyway just in case .. so ..
The left hand photon travels length L1 and encounters its beam splitter and the right hand photon travels length R1 and enounters its beam splitter. L1 = R1. In both segments the photons have a choice of traveling straight on, or deflecting 90 degrees (downward on your page if you are making a diagram). Consider only the photons that get deflected downward.
On the R side at distance R2 from its beam splitter is a screen with 2 slits, and beyond that is a solid screen. On the L side at distance L2 from its beam splitter is only a solid screen. L2 = R2, but the experiment is built so that distance L2 can be varied to a distance shorter or longer than R2.
I'm assuming the experiment can be set up so that an interference pattern will appear on the solid screen on the R side.
My question is this: As you adjust the solid screen on the L side, distance L2, longer than R2 to shorter than R2, will that have any effect on whether an interference pattern developes on the R side?
I would think that as long as L2 > R2 a pattern can be observed, but when L2 < R2 the interference pattern would disappear.
This is essentially what was discussed in the 'EPR and FTL' thread. If is possible, even in principle, to determine which slit a photon went through, you don't get interference. To determine which slit each photon went through, you need the 'which path' information, since this is not accessible after a photon goes through a regular double slit setup, you get interference. In your setup, the which path information is carried by the left hand photons, and it is possible to extract this information without measuring the right hand one directly, so you don't get interference.
However... I think if it is somehow impossible to tell which left hand photon corresponds to which right hand photon, it is impossible to tell which slit each right hand photon went through, so you should get interference. So basically I don't know what would happen! :( I'll leave it to someone more knowledgeable to answer. But I would say read the EPR and FTL thread, it might answer some of your questions.
Hmmm .. I take back what I thought it would do, as if it did you could fashion a sort of Morse Code FTL communication. I don't know what it would do.
FAQ: Even another 2-slit experiment setup
What is the 2-slit experiment setup?
The 2-slit experiment setup is a classic experiment in quantum mechanics that demonstrates the wave-particle duality of light. It involves shining a single light source through two parallel slits and observing the resulting interference pattern on a screen behind the slits.
Why is the 2-slit experiment important?
The 2-slit experiment is important because it was one of the first experiments to demonstrate the concept of wave-particle duality, which is a fundamental principle in quantum mechanics. It also has implications for understanding the behavior of matter at the atomic and subatomic level.
What is the purpose of adding another 2-slit experiment setup?
Adding another 2-slit experiment setup allows for further exploration of the wave-particle duality concept and can help to investigate the behavior of light in more complex systems. It can also provide more accurate and reliable data for analysis.
How does the setup of the 2-slit experiment affect the results?
The setup of the 2-slit experiment can greatly affect the results. Factors such as the distance between the slits, the size of the slits, and the type of light source used can all impact the resulting interference pattern. Additionally, the presence of any external factors or disturbances can also affect the outcome of the experiment.
What are some real-world applications of the 2-slit experiment?
The 2-slit experiment has numerous real-world applications. It is used in the development of technologies such as diffraction gratings, which are used in devices like CD and DVD players. It also has applications in fields such as optics, quantum computing, and particle physics, where understanding the behavior of light and matter at the quantum level is crucial.
