Events can be simultaneous in one time frame but not so in others
In summary, the recent forum thread discussed simultaneity and introduced the term "ansible line" (later referred to as "simultaneity line"). Einstein's thought experiment with lightning and a moving train showed that events can be simultaneous in one frame of reference but not in others. The questions raised were: 1) Can two events that are simultaneous in one frame also be simultaneous in another? 2) Can one always find a frame where any two events are simultaneous? 3) Can event A be simultaneous with both event B and C in different frames, and does this mean there is a frame where all three events are simultaneous? The answer to 1) is no, as evidenced by the linear relationship between the slope of the
  • #36
starthaus said:
I simply put the OP in mathematical form. There are only two frames in the OP, F and F'. There is no F". I think that we are interpreting the OP differently.
Yes, I think we must be.
stevmg said:
It would seem that an event A can be simultaneous with an event B in one FOR and also be simultaneous with event C in a second FOR. This does not mean that B and C are simultaneous but it should be possible to find an FOR in which they are. Again, this would NOT mean that [tex]\exists[/tex] an FOR in which A, B and C are simultaneous mutually, or does it?
The three frames, F, F', F'', I mentioned are: (1) a frame in which A and B are simultaneous; (2) a frame in which A and C are simultaneous; (3) a frame in which B and C are simultaneous. If we take the existence of F and F' as givens, then the existence of F'' depends on the nature of the separation between B and C.
  • #37
Sure, so depending how you interpret the OP, you get different results. I understand your answer (it is elementary) and , in the context of your interpretation of the OP, it is correct.
  • #38
Could you explain how you interpreted the question?
  • #39
See post 25.
  • #40
This is the post that started this from another ungodly long thread - hence we started anew.
AJ Bentley said:
Gentlemen, Please!
Humour me, have a go at this restatement of the paradox in a different form.:-p
Observer Alice, says to Bob ,who is just passing by at nearly the speed of light 'My Granny on Proxima Centauri is just sitting down to kippers for her tea'
Alice knows that because she has an Ansible (which allows her to see what Granny is doing right now without having to wait for the light to arrive)
Bob, who also has an Ansible, takes a quick look and says 'No she isn't, your Granny had her kippers for tea three days ago'
Explain.
You might like to show how Bob's Ansible allows him to travel back in time and re-experience events that have already happened.
What would Alice need to do to 'freeze' her Granny in time so that she is always having tea?
How long can she hold Granny frozen?
This led to my original three questions:
My original 3 questions (post 1):
1) Can two events which are simultaneous in one frame of reference (FOR) be simultaneous in another - that is - THE SAME TWO EVENTS, or is the simultaneity limited to only ONE FOR.
2) Can one always find an FOR in which any two event pairs are simultaneous?
3) It would seem that an event A can be simultaneous with an event B in one FOR and also be simultaneous with event C in a second FOR. This does not mean that B and C are simultaneous but it should be possible to find an FOR in which they are. Again, this would NOT mean that [tex]\exists[/tex] an FOR in which A, B and C are simultaneous mutually, or does it?
There were a lot of answers posted in that thread to AJ Bentley's question. My answer is noted below:
stevmg said:
By Einstein et al there can be no such thing as an Ansible. Basically, an Ansible literally establishes simultaneity between two events (the event itself and its observation in the Ansible.) This is not possible wrt to all frames of reference. Simultaneity "changes" (or can change) when looking at two distict events from the two different FORs.
The scenario descibed above is literally the Einstein train in which the lightning flashes are perceived as simultaneous in one FOR while in the other FOR, the lead flash occurs before the back flash. [Section IX, The Relativity of Simultaneity, Relativity, Albert Einstein.]
In this case, Bob is traveling towards Granny and sees her event to occur before Alice.
Lorentz time transformation and SR:
t' = [tex]\gamma[/tex][t - xv/c2]
Set t = 0 (for Alice,) x = whatever (call it x) for the distance between Alice and Granny in a common FOR. v is Bob's speed wrt Alice and going towards Granny.
Question 1)
WE ARE LIMITED TO ONE DIMENSION (two, if you include ct, and we translate the origin of Bob (who is traveling fast) to overlay the origin of Alice
Below is a schematic depiction of my answer`(the left members of the pairs are the distances, the right elements are the times). v ("approximately the speed of light") and x (the distance from Alice to Proxima Centauri) are arbitrary so are merely noted by v and x. Note that both v and x are positive. x', or the distance in Bob's frame, from him as crosses Alice to Granny is noted but not necessary for the discussion, while t' is calculated by the Lorentz time transformation. v for the Alice-Granny frame of reference is zero (= 0) while we just denote the velocity of the Bob-Granny frame of reference as v. is a positive number but not actually calculated here. t' calculates, by using the above information, to a negative number. This goes along with your supposition as presented.
Bob(0,0)......moving frame(v)......Granny(x',t' - a negative number)
Alice(0,0)......reference frame(v=0)...Granny(x,0)
In this depiction Bob is moving towards Granny. The Lorentz transformation changes to
A) t' = [tex]\gamma[/tex][t + xv/c2] if Bob is moving away from Granny.
B) t' = [tex]\gamma[/tex][t - xv/c2] is the original equation with Bob mving towards Granny.
We know that t = 0 at the origin and at the end of x (because Alice and Granny are stated to be simultaneous.) Since we are overlaying the origin of Bob's FOR on Alices and the story starts at the same instant for both, t' = 0. Assuming x and v are non-trivial, at the "end" of x' (Granny again) t' is NOT zero (t' [tex]\neq[/tex] 0) and thus the "beginning of x' and the end of x' are not simultaneous. This goes along with the story that Bob "sees" Granny eating her kippers before Alcice (both are looking through their simultaneity telescopes at t' = 0 and t = 0 respectively and t' and t are defined as being simultaneous - same point point, same time.)
By this scenario, the only way there can be simultaneity in Bob's FOR is for x or v to be trivial.
It is most important here to understand that I have limited this to a 2-dimensional (including the dimension ct) world. From now on I will refer to this as a one-dimensional world.
Starthaus interjected this beautiful calculus restatement of the same thing:
starthaus said:
The correct answer is "yes".
[tex]x'=\gamma(x-vt)[/tex]
[tex]t'=\gamma(t-\frac{vx}{c^2})[/tex]
so:
[tex]dx'=\gamma(dx-vdt)[/tex]
[tex]dt'=\gamma(dt-\frac{vdx}{c^2})[/tex]
If there is a frame where [tex]dx=0[/tex] and [tex]dt=0[/tex] then, in all frames [tex]dt'=0[/tex] (and [tex]dx'=0[/tex])
Keep in mind that in one dimension (say, the x-axis) the only way to differ in FOR's is by velocity or v. Using one FOR as inertial, another FOR is different only if v . In this one-dimensional world, t [tex]\neq[/tex] 0 for any x (at x'.) If v = 0, then we have simultanaeity for any x and its hidden twin x'.
By Yossels post, if we have a two or more dimensional world in which the axes are all orthogonal to the x-axis (say, the standard three dimensional world), we have as stated:
yossell said:
I *think* the answer to (a) [There are more than one FOR's that have points that are simultaneous with the original points] is yes. Imagine a frame F traveling in the x direction compared with frame G, and think about events that lie on the y-axis - that is, events that lie on a line at right angles to the direction of motion. I think both frames will agree on the times of such events, and two events simultaneous in G will be simultaneous in F.
There are thus an infinite number of simultaneity lines as the number of points on the y or z axes is unlimited.
I think starthaus's final statement, which I quote:
I can't think of anything that satisfies dt = 0 and dx = 0 other than an FOR which is orthogonal to the x-axis which agrees with yossell. If there is another I would like to know what it is.
Question 2) Does there [tex]\exists[/tex] an FOR for any two non-simultanous events that makes them simultaneous?
I haven't got a clue. I don't even know where to start.
Question 3) Answered by starthaus in post 25. I have another algebraic answer which is very tedious and I'm not sure is correct, so we'll leave it out.
  • #41
No, only if the events are spacelike separated.
  • #42
starthaus said:
See post 25.
I'm saying "if A is simultaneous with B in one FOR, and A is simultaneous with an arbitrary C in a second FOR, then it's not always possible to find a third FOR in which B is simultaneous with the given C; whether it's possible depends on the separation vector between B and C." (Did I misunderstand the question, Steve?)
Starthaus, are you saying "if A is simultaneous with B in one FOR, it's always possible to find a second FOR and an event C such that C is simultaneous in that second FOR with both A and B"? If so, then the condition is
[tex]t'_C=t'_A=t'_B[/tex]
which leads to djy's formula again, by eliminating [itex]t'_C[/itex], except that now it's v(F' in F) instead of v(F'' in F), and A and B instead of C and B. If [itex]x_A \neq x_B[/itex], then
[tex]v=c^2 \frac{t_B-t_A}{x_B-x_A}[/tex]
Since [itex]t_B=t_A[/tex], v = 0. Alternatively, if [itex]x_A = x_B[/tex], then A = B = C, so they'll be simultaneous in all frames, albeit trivially.
I still don't understand the statement in #25: "If you want for B and C to be simultaneous, this simply means [itex]t_A=t'_A[/itex]". The condition [itex]t_A=t'_A[/itex] makes [itex]x'_A=0[/itex], right? How does this ensure that [itex]t'_C=t'_A=t'_B[/itex]?
  • #43
Or a translation in time or space, or a reflection in time or space.
stevmg said:
Question 2) Does there exist an FOR for any two non-simultanous events that makes them simultaneous?
The answer is the same as for your original question 2: no. Such a frame only exists if there's a spacelike separation between the two events. If it's possible for information sent from one event to be received at the other event, you can't find a frame in which they're simultaneous. And if you could, it would lead to paradoxes.
Ah, so did I mistake your meaning in #31, etc? Were you comparing three frames or two?
  • #44
What's "OP?"
  • #45
In this starthaus did the work for three frames. I'll use that.
Starthaus used the term "OP." What does that mean?
  • #46
"OP" is widely used among many posters throughout different forums on the Internet as a shorthand for "Original Poster" or "Original Post".
AB
  • #47
Did you spot starthaus's post #35?
starthaus said:
Once again, my reading of the OP is that there are only two frames, F and F'. There is no F".
  • #48
AB
Got it...
